Thanks for the posts! I'm the new HS owner btw. ;o]
The machine will reset randomly, and it doesn't matter whether the game is being played or not. It's been moved to several different outlets on different circuits with no difference. The current circuit it is on is a newer circuit that is only being used by a TV, two lamps, and some other pinball machines. Nothing is currently on, just the one pinball machine so nothing is drawing power except this machine on that circuit. I have to eliminate this as an option.
So according to your description, it's not a slam switch type of reset. It just reboots, no message, just right back to the start. I do get a "ding" sound when it reboots, but I also get this when just turning the machine on. Slam tilt or just normal boot sound? maybe I'll make a video of this..
A couple of things you had mentioned I will check, such as the 5v power - if there is good documentation of how to check this online, can you point me to it? I'm not very electrically savvy in the pinball world, so I have some learning to do.
Coil Diode's - where are these? Keep in mind, it's not going to be anything mechanical (since it happens when the machine is just on and sitting there).
Al- btw, I fixes all of the switches, everything works - the left ball launch is still randomly triggering; it always triggers when you first turn on the machine about 6-8 times then stops, and randomly during play it will trigger about 6-8 times. weird, not sure what is causing this.
The dim lights (more they do not work) are definitely caused by the ground plate and/or the wire that grounds it. I was able to bridge it to another plate and make them all function correctly, though I removed this and will properly diagnose the problem.
thanks for the help everyone!
