The upper right flipper on my BK2K activates but will not hold in the up position.
I have replaced the coil, the EOS switch, the plunger and the coil stop. I also replaced the flipper button. The EOS switch is normally closed and opens near the end of the stroke. The other two flippers work fine. I have power at all three lugs and the flipper fires when you ground the center lug. What else can I check? I feel like I am missing something obvious.
How do I test the yellow capacitor? Does it matter which way it is wired on the EOS switch?
