(Topic ID: 295393)
System 11/Fire! - Strange reset/MemProt Failure/
By Switch
4 months ago
  • 17 posts
  • 6 Pinsiders participating
  • Latest reply 4 months ago by Pauz21
#1 4 months ago
Alright guys, So needing some guidance. Williams Fire! did a flipper rebuild, basic top side teardown and shop. Added a cointaker LED kit and now the game is having issues. Here are the symptoms:
-Game boots fine but randomly mid game it will just reset. Not always but id say every third game, but sometimes any game
-Reset once and gave the "MemProt Failure" message
-Sometimes it seems like the multiball sequence gets messed up and it decides to dropped locked balls when it feels like it.
-Game only did this once, but it seemed to lock up and the left lower sling shot kicked on and stayed on. I immediately powered off the game.
-Game has memory and maintains the freeplay setting when powered off
Recent things I have done to try to correct/troubleshoot the issue:
-When I brought the game home I found corrosion on the battery holder and replaced it with a remote mount. I can measure 4.5 volts at the board on terminals using B1+ and B3-
- Removed MPU board and reflowed all pins for the molex connectors.
- Checked power from the power board TP1=+4.97, TP3=+12.42 TP4=-14.54
- Ran CPU test with coin door open = LED indicator at U46 shows what looks like a zero,but half of it flashes in and out like a 7 almost??? When you first press the test button the U46 display briefly lights dimmly for a split second then the game seems to boot right up and do the 0/7 thing.
-Coil test runs fine with no issues or resets
-Switch test looks good with no unexpected closes on switches
-Coil door memory switch tests good
I am wondering if I am dropping power during play from the power supply causing a reset??? I am going to pull it out next and check for cold solder joints. Was thinking a cap kit, but the board looks like it has seen better days and thought of going to an Xpin replacement board. Think i'm chasing the right direction or possibly something else? Any suggestions or help would be appreciated.
#2 4 months ago
Please post a picture of the MPU and power supply boards.
#3 4 months ago
Hopefully this helps. I included a close up of the power board where it looks like it's gotten really hot. I unplugged the ribbon cable from the MPU board for a cleaner picture. Thanks for the help!
16241339082521222672818 (resized).jpg16241339429921523435631 (resized).jpg1624133964964848612202 (resized).jpg16241339902171734584718 (resized).jpg
#4 4 months ago
Quoted from Switch:
That is the high voltage section and will not do anything with game resets. I would start with new capacitors on the power supply and C30 on the MPU board. If the U25 RAM is already in an IC socket, I would upgrade to NVRAM since that would be an easy plug and play.
#5 4 months ago
My first thought was low 5v power with the mid game reset. Trying a different power supply board if you have one or have access to one. Definitely a CAP rebuild would not hurt.
One other thing I would HIGHLY recommend is to install fuse protection to your 2 B/R's. This is a known fire hazard if you get a short. System 11 Bullet proofing...
https://pinside.com/pinball/forum/topic/williams-system-11-bullet-proofing-thread#post-1211580
https://pinside.com/pinball/forum/topic/vids-guide-to-bulletproofing-williams-system-6/page/2#post-945742
#6 4 months ago
Quoted from PinballManiac40:
Sounds good! The U25 Ram is still soldered into the board. That's the reason I didn't go the NVRAM route in the first place. I don't mint soldering in components, but chips scare the crap outta me. I will get a new capacitor kit coming I think and just do them all throughout the game.
Quoted from Pin-Pilot:
Thanks a ton for the links!!! This is probably my 5th or 6th system 11 that I've gone through and I was not aware of the issue with the B/Rs. I really appreciate it!! I was thinking the PS was dropping voltage during game play causing the reset. It sounds like you guys are thinking the same thing and the Caps would be the easiest culpret to take care of first anyways. Really just general maintenance on these old games and keeping it simple is always the way to start. I just wanted to make sure I wasn't having some signs of RAM failure or anything more serious.
Now what are your thoughts on just buying a new Xpin PS board Vs rebuilding the williams powersupply??? in the past espically on the arcade side of things I have had a pretty mixed bag when rebuilding old power supplies. Seems almost better to just get the newer board with better modern designs. What are your thoughts?
ebay.com link: itm
#7 4 months ago
Existing board doesn't look too bad, just needs a bit of TLC.
#8 4 months ago
Quoted from Switch:
ebay.com link: itm
I replaced the PS in My High Speed - It was a good move. The background hum left with the old PS also.
#9 4 months ago
This could be a shot in the dark but with my F14 I had it where it was randomly releasing locked balls. Random tilts and random yagov kills. I replaced scr6 on the mpu (make sure you clip the 10th leg of the resister) and it fixed all issues.
I saw this on a series of videos on Joe’s arcade you tube Channel.
#10 4 months ago
Quoted from Pauz21:
Thanks a ton for the reply! I am currently watching the video where he is repairing an mpu for pinot. Hopefully this will give me some guidance. Since reflowing the connectors on the mpu board it hasn't been acting strange with odd ball lock behaviors, but it is definitely randomly ending the game still.
#11 4 months ago
Quoted from Switch:
You could send the board for the NVRAM to ChrisHibler . He would even check to be sure the switch matrix in case that is an issue, but it does seem related to the RAM circuit.
Or I'm sure you could find someone local you can trust to install NVRAM.
#12 4 months ago
Not sure if you pulled the power supply out yet, but you also have a row of 3 wires that are soldered directly to the back of the board connector that you will also have to deal with. You will need a crimper that crimps 0.093" pins. Also the male wafer for the board is kinda hard to remove without damaging the board, so extra care beyond even replacing the capacitors will be needed.
https://www.marcospecialties.com/pinball-parts/CKWMS
#13 4 months ago
Quoted from Switch:
Here’s the link to one of the videos in this series. If anyone isn’t watching Joe’s YouTube channel you should start. No one explains things better.
#14 4 months ago
Also check flipper diodes. If one is missing or broken, open. This can cause issues, lock ups resets. etc. Ive found many times on these older williams games issues by repeatedly hitting flippers cause a reset only to find an open diode.
#15 4 months ago
Quoted from PinballManiac40:You could send the board for the NVRAM to ChrisHibler . He would even check to be sure the switch matrix in case that is an issue, but it does seem related to the RAM circuit.
Well I live in the pinball wasteland known as Wyoming so out here I am about as good as it gets for board repair or pinball repair in general. There is only a few of us pinheads in the region even. I have used Clive over at The coin op Cauldron for board repairs in the past and have had great luck. The more I see everyone's comments it may be worth just sending out the whole board set to get looked at and gone through by a pro. I really enjoy game repair and learning more all the time, but board repair seems to be an art form when done correctly. I will see if I can repair the female end of that connect and probably just buy a new PS board.
Quoted from pinballplusMN:
I will look at those tonight. Thanks so much to all of you for your tips and expertise. Without people like you guys willing to share your knowledge this hobby would die out.
#16 4 months ago
Nothing wrong with replacing the board, especially with the shape that this one currently is in. If you do go that route, then you do not need the 3x4 board wafer connector, which is out of stock at GPE. They do have the other parts though.
https://www.greatplainselectronics.com/proddetail.asp?prod=03-09-1126
https://www.greatplainselectronics.com/proddetail.asp?prod=02-09-2118
https://www.greatplainselectronics.com/proddetail.asp?prod=02-09-1119
#17 4 months ago
Also a good suggestion. Before I turned to the board I checked all the diodes on my f14.
