(Topic ID: 282539)
System 11 (Cyclone) Bad power supply?
By DropTarget
#1 3 years ago
Arrrrrrrggggggg!!!!!
Today, I had my Cyclone powered up, I wasn't paying too much attention to it, but I heard several chimes, as though it was rebooting then, BAM! Everything went dark except for G.I. No display, no MPU test lights, no sound, nada. Should I assume power supply? I'm fairly unfamiliar with SS. How do you check voltage on the power supplies? If the machine sits, turned off for a while and I turn it back on, the knocker fires once, the +5v LED lights and then goes back out. All fuses check out good.
Thanks.
#2 3 years ago
Use a multi meter on power supply. I ended up swapping out my system 11 power supply. Also check all connectors on interconnect board. John
#3 3 years ago
Um, use a multimeter where?
#4 3 years ago
On output wires. DC voltage. It should be printed on boards.
#5 3 years ago
OK, Here are my readings. 3J5-4 and 3J5-3 are correct. 3J5-6 is only .65VDC, 3J6-2 is -43VDC, While all of the 5VDC pins on 3J6 read 1.3VDC.
Sounds like a pretty sick power supply. Any thoughts on what to look at?
#6 3 years ago
Quoted from DropTarget:
Yeah. Just get a rebuild kit and replace every capacitor on that puppy. If you have issues with the high voltage section, get a rebuild kit for that as well. It’s not very hard to swap the caps! Just did my whirlwind not long ago and solved the occasional no boot on first attempt.
BE059CC7-071D-4B88-B4FD-2A8D4303C9E3 (resized).jpegBE059CC7-071D-4B88-B4FD-2A8D4303C9E3 (resized).jpeg
#7 3 years ago
thanks,
I was going to buy a replacement board, but would rather not spend the bucks
Mine is doing, or rather not doing much more than rebooting. It doesn't boot at all, no CPU LEDs, no displays.....
3,200 (Firm)
Collegeville, PA
$ 36.95
$ 11.95
3,650
Copley, OH
$ 12.50
RoyGBev Pinball
$ 29.99
Daddio's 3D Printed Mods
$ 2.50
$ 69.00
Pinball Pimp
$ 18.95
$ 170.00
Displays
Digipinball Shop
$ 27.00
$ 19.99
$ 69.00
Pinball Pimp
$ 39.99
Gweem's Mods
This page was printed from https://pinside.com/pinball/forum/topic/system-11-cyclone-just-gi and we tried optimising it for printing. Some page elements may have been deliberately hidden.
