I picked up a clean System 11 Cpu for my Whirlwind, the CPU is clean with no battery acid damage or hacks. The board does not boot - the 1st LED is on, I believe that is the 5 volt Led. Things I have done, I changed ZR1, ZR2, Q34, Q36,Q38, C30, R55, R56, U11, U25 & U13. The CPU processor chips and eproms are good, I checked them in a working board. I have metered all the PIA with a multimeter checking for shorts, checked the reset line for low to high when you power up the board. All voltages seem to be correct - I suspect one of the PIA's are bad, is there a way to check them without removing them all and replacing them? Any other ideas of what I might be missing? Thanks for your help.
