I am stumped. Have a coil that locks on immediately at power up. Solenoid 05A, lower right eject hole. If I disconnect J11 on the MPU the coil does not energize, so I assumed the problem was on the MPU, not a wiring issue. I replaced the TIP122 and predrive transistor 2N4401 associated with that solenoid (even though they tested good on the bench). I tested the associated diodes for that solenoid on the auxillary driver board and they test good (with J4 the auxiliary driver board disconnected). I tested U19 on the MPU per the wiki test instructions and it appears good. What am I missing? Should I change U19 or is there something else I should be testing?
