(Topic ID: 43458)
System 11 Club !
By mof
6 years ago
  • 3,017 posts
  • 618 Pinsiders participating
  • Latest reply 4 days ago by king-pin
  • Topic is favorited by 270 Pinsiders
There have been 611 images uploaded to this topic. (View topic image gallery).
There are 3017 posts in this topic. You are on page 60 of 61.
#2951 56 days ago
Quoted from Scrimmbo:
Do you think I should change Br1? Seems like the only bridge on the P-supply board. I have a few KBPC3504-W's laying around. That's a 35a 400v bridge, would that work as a replacement?
Since the noise goes away when you remove F-1 fuse, the issue is the high voltage portion of the board. You could check for AC volts on each of the +/- 100 volt circuits.
#2952 56 days ago
Quoted from GRUMPY:
I will do that! the +/- 100v is used for the display correct? Might be worth mentioning that I replaced the original displays with a pinscore board, the noise was there before I swapped that though. Also, not sure if I mentioned it earlier but the noise usually goes away if the game is on for a little while. Anyway, I will take a look at the high voltage circuits and see what I can find, thanks a lot for your continued help!
#2953 55 days ago
When you want to fix the battery holder with a nice fitting/bolt or whatever...lol
#2954 55 days ago
Quoted from onlydjz:
Fix one problem... Create another problem... Whoa
#2955 55 days ago
So over the Christmas break I was able to change C8, I went ahead and changed C7 as well, just because I wasn't positive I had changed it last time. Hooked it up last night, and it's still singing! So onto the next thing!
What brand capacitors are you using?
Does this sound level on the noise change as less text is shown on the display?
#2956 54 days ago
Looking for thoughts and ideas I've had a SOF for quite a few years. I bought it and from day one it had "ghosts in the machine" boot issues etc... When it worked great fun to play but it stopped booting and I left it sit for several years and finally got back to trying to troubleshoot the issues. So it still would not boot, did multiple cycles and viola it boots. So I play several games and begin smelling heat/smoke. The outhole kicker is hot, I mean really hot, too hot to touch hot. I cycle the machine off and on and the outhole coil locks on. I changed out the coil(with a comparable coil, I ordered a proper replacement AE-23-800), coil still locks on on boot, but the machine consistently boots, (Q33 transistor tests okay with a MM in the machine.) I unplugged the 5J4 wiring from the Aux Power Board, machine continues to boot ok. (If I plug the 5J4 connector back in the coil locks on immediately.)
I have a new Rottendog CPU board but I am concerned that if the problem is on the Aux Power Board I will fry something on the new Rottendog CPU.
Help!
#2957 54 days ago
Quoted from PAR:
Is this on the original board?
Quoted from PAR:
The outhole coil is controlled by the CPU not the aux power supply. So the problem should be on the CPU.
#2958 54 days ago
Anyone know where to score some Chrome Rivets to attach my 'Bally' Logo to the speaker cover panel?
#2959 54 days ago
Quoted from guitarded:
Id use nickel rivets.
#2960 54 days ago
Quoted from GRUMPY:
Yes It is, all the boards are original.
I'll plan to swap the CPU and see what happens
Thank you
#2961 54 days ago
Quoted from PAR:
Thank you
Ugh, broke a leg off one of the micro processors while swapping out chips to the rottendog board, (the last chip of course, an EF6802P at U24, so now I am dead in the water until I find a chip, any one know a good source for this particular chip?
#2962 54 days ago
PAR, check out Great Plains electronics.
#2963 53 days ago
Quoted from PinballManiac40:
There are a few different brands of caps in there, I used the autozone method, which is to say, I didn't buy the cheapest caps I could find, but I also wasn't buying the most expensive. Some I didn't have much choice as there were only a handful available in that certain value or style. The noise does not seem to fluctuate with the display being lit, I do however have some noise coming through the speakers that seems to change with the display. I think this is usually a ground problem on the sound board, I'll have to clean up those screw terminals nice, but it doesn't really bother me all that much.
I did some poking around in the high voltage section of the power supply, the 100v measured at 99v which I think is within spec, I didn't really find anything else glaringly wrong here, I did clean up some solder joints and stuff, but the issue persisted. So, for now, I've just pulled fuse F1, not the greatest solution, but since I've updated my display there is nothing else that uses that voltage anyway. I play tested the game just to be sure of that, and yeah, everything plays normally.
Thanks again to all of you who were giving me suggestions, I appreciate it a lot.
#2964 49 days ago
Quoted from PAR:
Just a follow up, new chip arrived, plugged it in to the daughtboard and booted machine successfully, Lionman lives! Thanks to all for the help
#2965 43 days ago
Hey all. So I am re-joining the Sys 11 club, I have someone shopping a Jokerz for me.
What I'd like to know, is if there are truly any above 3K System 11 titles? I'm looking to grow my collection and have seen some what I would say wonky pricing. Now I know people can ask what they want, but I was wondering about your input?
Ps. I'm looking for a Police Force next.. my son is into Police/Fire cars/truck stuff!
#2966 43 days ago
Quoted from Silvercoin:
I’ve owned a few system 11s (still have/love Mousin Around) and the only system 11s that probably deserve to be over 3k would be Banzai Run or gorgeously shopped-out/refurbished games like Whirlwind and Elvira. Maybe a couple of the “rare” system 11s that are in great shape like Transporter or Radical.
Just my thoughts.
#2967 43 days ago
They only ones I think are worth over $3k are BR and BC (only because it is hard to find) - Most System 11 games should be in the $1500-$2000 range depending on title. Would love to have them all but not paying $3k for MA or a freakin earthshaker
#2968 43 days ago
Quoted from woody76:
I think you are on the mark for the majority of system 11 games but condition is king and a true HUO system 11 (or one that has been reconditioned over the years with NOS parts) in amazing shape should fetch mid-to-high $2k in today’s market.
#2969 43 days ago
Quoted from Ranhorton:
for sure, I am just talking your basic average shape system 11. I have several and love them but they are all pretty similar in game play and scoring. I just can't see spending $3-4k on a system 11 except for BR and maybe a nice BC or EATM
#2970 42 days ago
You all need to come out to the west coast, you wouldn't touch a popular system 11 in nice shape for the kind of money you are tossing out there.
#2971 42 days ago
Quoted from Billy16:
just picked up a nice police force for $1000, got a mousin around for $800, high speed for $500. They are not QC or anything but nice players
#2972 42 days ago
Well, I will probably be selling my Mousin' Around soon, and though it is strictly a player's quality machine, there is no way I would sell it for $800 (or even twice that).
If that's what they are going for, I'll just keep it.
#2973 42 days ago
Quoted from mbeardsley:
They go for more, I found it in a antique store and they did not know how to turn it on so thought it didn't work.
#2974 42 days ago
$1k might get you a nice System 11 Cabinet in the intermountain West. It would probably need repairs, though.
#2975 41 days ago
Just joined the System 11 club with a project Taxi. Took a little to get working but new playing well except for a shorted knocker coil.
One question: there are no flipper switch capacitors or flipper capacitors. There should be right?
#2976 41 days ago
Quoted from Barr993:
Yes, there should be capacitors. (see attachment)
#2977 37 days ago
Both right flippers on my Transporter the Rescue are suddenly not working. Where would you check first? Thanks!
#2978 37 days ago
Picked up a space station and got bk2k back in the line up. Never played space station. It’s not a bad pin. I love the multiball but I think bk2k is still one of my fav system 11s. Space station I don’t think will have the staying power as bk2k for our line up
2FD23AC2-EA2E-4B71-9FE9-C9D93624A375 (resized).jpeg4B482F03-9E2D-429A-B55D-2554ABB628D7 (resized).jpeg
#2979 37 days ago
Quoted from mulder2010:
Fuse on the aux power supply.
#2980 35 days ago
Anyone have a sys 11 service switch laying around? (Or a link to a site that has them in stock) I tried to find one in the various stores, but only see the 4 button version. It's for a Sys9 Space Shuttle technically, but same as the other earlier WMS systems
#2981 35 days ago
Quoted from statictrance:
digi key - I bought the individual push button switches and replaced the bad ones instead of a entirely new 3 button switch
Grumpy turned me onto these folks. Got tons of cool stuff.
#2982 35 days ago
I bought my replacements from Digikey also. Here's what I used:
outside black switches: https://www.digikey.com/product-detail/en/c-k/F2UOA/401-1225-ND/417519
middle red switch: https://www.digikey.com/product-detail/en/c-k/F2UEE/401-1223-ND/417517
They also sell the coloured caps, but you can just pull the old ones off and push them onto the new switches.
#2983 34 days ago
Yeah, I'd expect to pay in the neighborhood of 3k or more for a nice example of BK2K, Elvira, or BR here. Transporter more still but that's a rare enough game that it's a national market.
#2984 34 days ago
Quoted from GRUMPY:
2 amp s/b! Replaced that and now it's fixed. Thanks!
#2985 34 days ago
Playball!
#2986 30 days ago
Need some help finding the correct "cam" for a backbox lock.
My Mousin' Around is missing the flange for the lock that actually holds the backglass in place (preventing it from being lifted out).
The manual seems to indicate that it is part 01-9358, but I have not been able to locate such a part.
I would think that this part would be shared by a bunch of machines that have a similar backbox mechanism.
If anyone knows what part this is, and/or where I could find one, I would appreciate it.
If anyone could provide a picture of the inside part of the lock (so at least I know what to look for), that would be helpful too.
Thanks.
#2987 30 days ago
I haven't found one. I made my own with a pair of regular cams...
#2988 29 days ago
Thanks, that's helpful.
#2989 29 days ago
Any idea what specific parts you used to make that?
I haven't been able to find those parts either, or did you bend/drill them yourself?
#2990 29 days ago
Yes. They are the basic cams that come with any lock...
https://www.marcospecialties.com/pinball-parts/LKTS2201-17
If you're not placing an order, it may be easier to just go to the hardware store and buy a couple of cheap locks. Or use scrap metal. Although filing out a square hole would be a pain.
#2992 25 days ago
Just re-joined the Sys11 club!
Picked up a Jokerz yesterday, and its a great game. Sold all my pins 3 years ago, and have cursed that day since.
Looking for more already. BK2K, Police Force, BOP, and a cpl others..
Only issue with this one is the flashers on the ramp are missing their wiring.. need to look into that.
#2993 25 days ago
Well, in going through my box of random parts, I found the original cam for the Mousin' Around!
However, it seems that I have the wrong lock installed in the backbox. The lock seems to expect a cam with a much smaller (and almost oval shaped) hole, not the larger square hole that the correct cam has.
The picture here shows the cam that fits the current lock (but doesn't work with the backglass) on top, and below shows the cam that is supposed to be used.
So, now the question becomes how do I buy a replacement lock and know that it will fit with the cam shown below?
#2994 25 days ago
https://pinside.com/pinball/market/classifieds/ad/91025
Just posted space station if anyone is interested. Great pin but Bk2k is our favorite system 11. Its the only one staying in the lineup
#2995 25 days ago
So, now the question becomes how do I buy a replacement lock and know that it will fit with the cam shown below?[quoted image]
https://www.marcospecialties.com/pinball-parts/LKA118
Most cam locks you buy have the correct sized square cutout, unless they are tubular key locks they usually have the smaller type. The ones that PBR sells are usually the 1382 key with the correct cam as well.
#2996 25 days ago
Still haven't gotten bored..
#2997 25 days ago
Jokerz! is a great game once you get it tuned properly. A lot of people like to crap on it as one of the worse System 11 games, but if you learn how the table shots all work, you can rack up some good scores, even without the DYS. Sure, the rule set is a little shallow but I think a lot of people don't also realize that not many games of this era had a super deep rule set. I picked one of these up back in September and have been fiddling with it and ALMOST have it where I want it. I really like the table and am hoping to eventually get a Taxi and a Cyclone to put next to it.
#2998 25 days ago
Sign me up. I have an Earthshaker and F14. Had Fire a few years ago. I'm a fan of the system 11 games.
#2999 25 days ago
Looking to sell a nice clean Rollergames for $2100. Need to thin the herd.
#3000 25 days ago
Quoted from Mr_Frog:
Jokerz is a great game.
All Sys11 games are reasonably shallow.
Most have 2-3 things to do. Jokers has more than most.
- multiball
- left orbit build up value
- right orbit spin the wheel
- build ramp value on the left, collect on the right
- 1m shot from the drops
- double score last ball.
Mine has fixed 4m jackpot value - it’s one of our most played Sys11 games.
If people don’t like it - well, that’s on them.
rd
$ 79.95
$ 399.95
Pin Stadium Pinball LEDs
$ 29.99
$ 45.99
$ 49.95
