Hi all
Its a #Road kings. Having a problem with the left bottom kicker. Switch works fine during game but does not trigger the coil.
I'm thinking its the A/C relay?
I re-flowed solder on it , changed the diodes , traced all wiring .
-Coil does not work in test
-Coil works by grounding transistor
It did have a special coil locked on when i got it and a burned out a transistor and U45. I replaced them and all is good with that but, cant figure this one out. I cant seem to find where in the schematics this relay is.
Help!
Rob
