Not sure about that. What I do know is, all Gottlieb System Ones with the sound board are downward compatible if you want to install a chime box.
Hello,
Yes, you can very well control the "bip-blup-555" Gottlieb board from a different source.
This card is very basic, it has three circuit-based oscillators 555, each triggered by the grounding of a pin.
The three frequencies generated (594 Hz, 266 Hz and 153 Hz) are then mixed and amplified by a LM380.
It require a 24 v DC power on pins 9 and 6/7 (GND).
The tones are activated by grounding one (or more) pin : 1, 2 or 3
- Connected to ground = tone
- Not connected = no tone
The board has been designed to replace directly the xylophone coil controls (similar, activated by grounding).
Thank you for the thorough response! I am going to play around with some other sounds for Count-down. It's sitting next to Dragon and if both machines are being played at the same time the sound can be a little maddening.
This page was printed from https://pinside.com/pinball/forum/topic/system-1-soundboard-switch-a-roo and we tried optimising it for printing. Some page elements may have been deliberately hidden.
