(Topic ID: 276747)
System 1 solenoid stuck on
By Clintonian
1 year ago
  • 2 posts
  • 1 Pinsider participating
  • Latest reply 1 year ago by Clintonian
    #1 1 year ago
    Hey guys I recently picked up a Solar Ride that has aftermarket boards. Rottendog driver, power and niwumpf mpu. After about 30 plays there was a bit of burning smell/smoke coming out of the back box. I found the drop target solenoid cooking hot. Also there was a 5A fuse (instead of a 2A slo-blo) for the coil. I don’t have any info on the new boards so I’m unsure what to check. I removed the fuse and the game boots and works as it should (minus the target reset). Any troubleshooting help would be much appreciated. Thanks in advance.
    #2 1 year ago
    Issue solved. Q45 transistor fried. Replaced. Also replaced coil and diode. Previous diode wasn't soldered onto lugs, only wrapped around. Works great now.
