Quoted from hockeymutt:So I have re pinned all connectors, game scores and plays but still am getting all 3 tones at once constantly and found knocker coil was locked on. And center bumper doesn't actuauate when hit but does score.
This is a bit funny - the pop bumper scoring switch is actuated by the pop bumper. As in, if you put in switch test, you would get the pop bumper switch to register by pushing down on the ring - not by pushing the skirt. If pushing the skirt activates the score, then it is wired wrong.
Quoted from hockeymutt:Checked the transistors they all seem fine have slight discoloration on the chips on the driver board.
Does this sound like a driver board issue?
Possible the driver board, but if you were looking at the transistors, then you would be talking 4 of the 8 as having failed. That would be a pretty rare failure.
I recently had a driver board that had a bit of corrosion on the edge-connector header. It didn't look serious - just slightly dull, or matte colored. But it was enough to prevent sufficient contact. As a result, the drop-target reset coil locked on. My suggestion is to check all the edge-connectors are both the driver board and the MPU.
