Ok so im an EM guy but picked up a Joker Poker. Board work and testing is new to me but I can do anything, im not scerrd . Of course it doesnt work but thats to be expected with the games i buy.
I started in on this today and this is what i found
Based on Clays guide i tested the top connector. DC Voltage I got -12 on the right pin. on the two left pins Im supposed to get 5v but got .98 v using the capacitor for a ground
So I moved to the bottom connector im supposed to get from left to right AC Voltage
11v 11v 14v 14v 69v 69v
i get
11v 11v 14v 14v 34v 34v.
Im using the COM on pin 3 for the ground for the bottom pins.
the questions are. Am i testing the bottom pins correctly? If so and 34v is what im getting, where do i check next? The bridge rectifier? The transformer?
Im super new at boards so be gentle
Thanks,
Jeff
