I have a System 1 display in a Joker Poker that is missing a couple of segments on the 1st and 4th digits. If I press on the display board just above the connector I can make it display all digits properly. No broken traces on the board, re-soldered all pins and connections on the board. The connector is fine because the problem follows the display in question.
Is it likely a bad connection from the board to the display glass? If so, anyway to fix the connection? From looking at the display I don't see how that is possible.
