(Topic ID: 247566)
System 1 Boot / Dip Issues
By MaxAsh
7 months ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 7 months ago by MaxAsh
#1 7 months ago
Hello All - I picked up a Gottlieb System 1 Genie recently, and have run into some issues. I'm going through the repair guides, but figured I would see what people thought as I wait for parts and such. When I power it on, I get a variety of results:
* Just GI, no boot
* It will boot after the 5 second delay as expected, displays go all zeroes, and I can credit up and play (though it acts strangely, more on that below)
* GI comes on, but a bunch of inserts are lit as well. The game won't boot and all the lights (including the inserts that shouldn't be on) stay lit
Sometimes it will boot fine a few times in a row, other times I have to turn it off and on a dozen or more times to get it to boot up. Some of the strange issues once it does boot include:
- The game will only take a maximum of "1" Credit
- Regardless of DIP switch settings, the game is always 5 ball, and I always have to trigger the coin door switch 5 times in order to get the 1 credit. It's as if the DIP switches do nothing at all
- The game normally plays great once it boots, but on rare occasion it will act oddly, like giving me a bunch of advance bonus triggers for a single target hit, racking up way too many points. This is not common, but happens now and then.
Some things I've done (NOTE: The boards were extremely clean)
* The original Data Sentry battery was there, but had not leaked. I removed it and installed a remote battery pack.
* I also replaced C1 on the power supply, so that's nice and new. I pulled all the connectors and cleaned the edge connectors on the boards (they were already really clean, but just in case).
I have not repinned all the conncetors yet, I needed to order the connectors, which arrive soon. In the mean time, anyone experience these odd behaviors? Suggestions? RAM maybe?
#2 7 months ago
I worked on a Pinball Pool for a customer that exhibited all of the symptoms yours is. I tried everything you have and more.
I either replaced the CMOS or made a recommended modification to the power circuit, maybe both.
I modified the reset section in case that was preventing it from booting.
I had replaced the power supply and it was spot on.
The MPU was perfect with no sign of physical damage or battery corrosion. Ultimately, I gave up and ordered a NiWumpf. If you get yours figured out let me know, I still have the original MPU.
#3 7 months ago
Hmm, that's not encouraging. Hopefully I can figure it out!
Minor update to the above: I also did the ground modifications for the CPU and driver boards.
#4 7 months ago
Just found this on flippers.com's repair site for System 1:
Symptom: Game will register only one credit when coins are deposited and the book-keeping memory appears to be blanked.
Solution: Power supply capacitor C2 (220pf) limits high frequency noise on the +5VDC supply. If this capacitor opens, the bookkeeping functions will be inhibited.
I'll look into that in case it's related.
#5 7 months ago
I believe that’s the upgrade I did and it made no difference. I also did the ground mod.
#6 7 months ago
Verified I have 5.04VDC and 12.12VDC on the MPU at the capacitors as expected, so the power incoming looks good.
#7 7 months ago
Started repinning connectors last night. I'm not confident that will help though. Does anyone have other suggestions on what might need to be looked at? Thanks
#8 7 months ago
You did not mention battery situation but even if you think there is no or little leak or corrosion this is what fixed mine when I could sorta play but it acted wonky. Check all traces and socket/replace the 3 chips in the pic.
#9 7 months ago
The battery had not leaked at all, everything looked great. Already been replaced and I checked everything, it all tested fine... but I'll keep that in mind. I guess I could borrow a friends System 1 board and swap them to see if that helps perhaps?
Senoia, GA
€ 8.40
$ 69.95
$ 289.00
$ 9.95
Apparel - Unisex
Pinball Wheezer
$ 9,099.00
$ 19.99
$ 11.00
$ 99.00
Docquest Pinball Mods
$ 7.00
APB Enterprises
$ 164.99
PinballBulbs
$ 159.99
TheDudeMods
$ 18.99
