I'm working on a System 1 that I bought not-working. I've got the power supply rebuilt and working with proper voltages, but can't figure out a fuse blowing problem on the 69v circuit. I've narrowed things down a bit - for it to blow, which it will continually, I have to have the following connections
1. power supply (A2J3) to displays
2. power supply(A2J2) to CPU Board (A1J1)
3. A1J3 plugged in connecting CPU board and displays (the lower of the connections to the displays)
All my displays are unplugged, as is the connections between the driver board and the CPU board. I've examined the wiring, the connectors, and the wiring jumper bakelite boards on the light board for shorts, but none found. I've also swapped CPU boards, but same result. Note: Neither CPU is known to be fully working, I just haven't gotten that far.
I'm lost at this point. Anything obvious to check? In the meantime I was going to try and verify the pinning of the connectors used, in the case that someone repined them wrong before I got the project.
Thanks in advance,
BTW
