I have Gottlieb Arean that plys 100% other than no sound and the dip swithes are not working after the switch matrix was shorted to solenoid voltage. I have a different thread with regards to the sound problem.
So this is what I have so far.
No dip switches are registering. As it says in the manual, when I go to test mode turn on all the even number and turn off the odd dip switches it displays 00 00 00 00 instead of AA AA AA AA. When I turn off the even numbers and turn on the odd numbers it again shows 00 00 00 00 00 instead of 55 55 55 55 55.
So obviously the microprocessor is not seeing any of the switches. I have already replaced U4, and z14. Other than DIP switches not working and no sound, the game plays 100%. The diodes associated with the switch banks test good. I have checked traces between z15 and the the diodes that are connected to the switch banks and they test good. I assume Z33 to be good since the rest of the game and lamps play correctly. Z13 tests good and z15 has both high inputs and outputs in attract mode. (suspicious of Z15 since it is connected to all the switches)
suggestions on what would keep the micro from seeing any of the switches?
(also if anyone wants to explain the function of z15 and z33 and how they interact with the rest of the switch matrix I would appreciate it.)
thanks
