Working on a black hole, originally with ni-wumpf boards. When I got it I replaced all the burnt out lamps, and they all worked. A bit later I noticed the top middle lane (L42) had stopped working, so I went to replace it again, but the bulb was still fine. Tracing back I found out that the transistor for this bulb had failed, so I replaced it. Lamp worked again for a while, and then the transistor failed again. And again. I figured it might be the ic driving the transistor and just ignored it.
Then I swapped in an original sys80 driver board, with all tested transistors. Lamp worked again for a few minutes and then the transistor on this board blew as well. So it must be something external to the board. Nothing is shorted against that socket or anything that i can see
