I got the following board in my BK2K. The head was involved in a flood and half the CPU board sat in water for a couple days. Luckily it stayed in the same climate, dry and seemed to have limited damage. The board started acting a little wonky with the drop targets and I found D2 had rusted through a leg and have not troubleshooted anything else. Easy fix, but the question is... is it worth fixing?
Is there any way to eliminate rust on a board? I would like to salvage this board... but obviously I can use it for parts if needed. I was thinking of throwing a bit of evapo rust on the board and then drying it out after... but is it circuit board safe?
Thanks for any advice.
edit. Yes i know the battery holder is really really bad
