Working on a Gottlieb count down (original boards), and I noticed when any of the displays 'change' they all flicker slightly. Most noticeable is when a player is up and one of the displays flashes to indicate that player, all the others flicker a bit in time with the flashing, but it also happens when you score and the display increases.
I figured the voltage was probably low or the capacitor was bad (since it still had the original psu board), so I put in a new rottendog psu board, but it didn't help at all. (in fact I feel it may have made it slightly worse but I don't want to swap the old one in to compare again...)
Looking at the schematics I don't see any other capacitors anywhere or anything like that. Is there anything else that could be a problem?
