.25 slow blow high voltage fuse blows at power up.
just looking for info on what the usual suspects of this issue could be.
thanks.
thanks.
Could be a problem with your displays or your hv regulator section. Try unplugging 3J5 and seeing if it still blows
It never happened to me, but first I would try to disconnect the displays in order to exlude them on the possibilities (maybe it's irrilevant).
Then, if the power form the transformer is good, I would start checking components oin the HV area: capacitors, zener diodes and both obsolete transistors.
thanks for responding.
I should mention main edge connector on display board (at work, forgot what its labled), has melted wire goo in it. it needs to be replaced. sounds like that may be a culprit of fuse blowing.(I had been thinking it was a sign of the problem, not THE problem)
something I find interesting is after fuse blows, displays still flash gibberish while attempting to boot (game has boot/resetting issues as well). I would have assumed once high voltage fuse blows displays would not work at all.....
This page was printed from https://pinside.com/pinball/forum/topic/sys-6-high-voltage-fuse and we tried optimising it for printing. Some page elements may have been deliberately hidden.
