"The driver board driver transistors are the most probable source of solenoid problems. But an easy first test is to measure the voltage at connector 3J3 pins 6-9 on the power supply board, which should show about 28 volts DC. If there is no voltage, check the solenoid fuse F2. If there is a lower voltage, the backbox mounted bridge rectifier has probably partially failed. If the voltage is higher than 28 volts, don't worry about it (as long as it's not more than 47 volts!) The "unloaded" system should measure higher than the "loaded" 28 volts DC."
I'm not getting anything on those pins with my MM. Ordered a rectifier as well....
