(Topic ID: 7597)
Sys 11 / Early WPC playfield support mod
By SealClubber
9 years ago
  • 13 posts
  • 5 Pinsiders participating
  • Latest reply 9 years ago by gweempose
#1 9 years ago
Has anyone put a late WPC playfield support mechanism in an early WPC/sys 11 game?
Working on my TAF is a real PITA with the old style pivot. My BOP has the same set up. I want to be able to slide out the playfield. Has anyone done this?
#2 9 years ago
That's an interesting concept, SC. I'm sure it would be possible. The playfield support mechanism is currently broken on my STTNG. I'm wondering if anyone sells the bolt that screws into the side of the cabinet. Mine is missing one.
#3 9 years ago
Quoted from SealClubber:
I've looked at the new style and had the same thought. From a mechanical point of view as long as everything clears the play field parts and the wire harnesses are long enough it is doable. Just get the alignment straight for a smooth movement...
Quoted from gweempose:
I think it's a 3/8" X 3" carriage bolt. Available at any hardware store.
#4 9 years ago
Thanks, but I actually need the tubular bolt that screws on from the inside. In the photo, you can see that the one on the right is missing. You can also see how scraped up the paint inside the cabinet is from the sides of the playfield rubbing against it.
#5 9 years ago
Your "tubular bolt" is often referred to as a Threaded Standoff:
http://www.mcmaster.com/#standard-threaded-standoffs/=ew3tgk
#6 9 years ago
Quoted from vid1900:
Threaded Standoff
That's the gist of it lol, I would get it for the machine due to configuration.
Side note: That guy from Phantasm freaks me out just to look at him! Movie quote: "NO! It's not".
#7 9 years ago
Thanks a bunch! So I guess my next question is what is the exact one I need, and where can I find it? I haven't any luck at the normal online pinball parts stores.
#8 9 years ago
Thanks a bunch! So I guess my next question is what is the exact one I need, and where can I find it? I haven't any luck on the normal online pinball parts stores.
Well, if it is 3/8"-16 like jrrdw says, then you need to measure the length to pick the one you need at Mcmaster.
#9 9 years ago
Also, you can get them with a hex shape rather than a round tube.
Easier to grip with a Crescent Wrench for sure.
#10 9 years ago
Marco doesn't have it under cabinet parts? Take careful measurements and get one from the link vid1900 gave. Us spud cannon builders get parts there often, they have a very large pneumatics section lol , high on the shipping cost though.
I see on ebay people selling used hardware grab bags from pins, keep your eye out there...
#11 9 years ago
Quoted from jrrdw:
Good call! I didn't think to check by category. I think this is it ...
http://www.marcospecialties.com/product.asp?ic=02%2D4329%2D2
They call it a "Pivot Nut". The weird thing is that it doesn't list STTNG under compatibility.
#13 9 years ago
Thanks, dude! I had the wrong size. That's definitely the correct part!
$ 999.00
$ 39.99
Lee's Parts
