(Topic ID: 226458)
Sys 11 component help
By Tomass
5 years ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by Tomass
#1 5 years ago
Thanks in advance for any help on this. I am starting to work on a battery damaged Pinbot mpu and want to source the correct components. I am wondering about the following:
1.) Several components are just labeled (b) and it is a blue axial component.
2.) When replacing capacitors; can I use a higher voltage as long as farads are equal? And what is the + - rating on these? One shows +80 -20%
3.) Sr8 and src6 are listed as the same but the other src components list a resistance and a capacitance rating.
4.) I believe I can use mc6821 where it shows 6820/6821.
5.) Some ic chips have additional coding after the numbers, does this mean anything as far as replacing the original? (ie 6821p vs 6820)
#2 5 years ago
1) B is 0.01uF,50V,+80%,-20% axial ceramic capacitor.
2) I believe your statement is true. The +/- are the tolerance ratings.
3) Do NOT confuse the "SR" with the "SRC" components. SR are network resistors. SRC are network resistors with capacitor. SRC components are no longer manufactured but you can leave off the capacitor component and use 9-pin,8R network resistors. See http://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#Repairing_Alkaline_Corrosion for more details on this.
4) Yes. A 6821 is a 6821. Does not matter what company manufactures it.
5) Those letters are usually codes for certain things. There are sometime letters between the numbers (e.g. 7402 vs 74HC02 vs 74HCT02 vs 74LS02) and those may make a difference.
Good luck with your repair. I would advise you check your traces before putting any component back on the board as it's easier to see and fix the traces without components on the board. You also do not want to unnecessarily undo any work you have done. Most of all ... enjoy the ride. It's often a LOT of work but when it finally works it's satisfying to bring a board back from the dead.
#3 5 years ago
The confusion on src6 is that it is listed in the manual as only a resistor pack. Same as sr8. Is this a mistake in the manual?
#4 5 years ago
That (by hand) manual correction is INCORRECT. Here's the reasoning (and logic) for that conclusion.
System 11 (used in High Speed and Road Kings) has SRC6 and it's listed as component 87 in the component list. It is 8R,8C,10-pin,1kOhm,0.001uF. It's used as a pull-up resistor on the switch columns (drives).
System 11A (used in PinBot among others) is a System 11 board with diagnostic LEDs instead of the 7-segment LED display. It should have SRC6 just above the 1J8 connector.
System 11B (used in BK2K and Whirlwind among others) is a System 11A board with connector 1J9 removed. Components in the switch matrix area have a different layout and SRC6 was removed and replaced with discrete resistors (R138-R145). It's electrically equivalent.
If you have a System 11A board you will need SRC6 as a 8R,8C,10-pin,1kOhm,0.001uF network resistor. As this is no longer manufactured you can replace it with a 8R,9-pin,1kOhm resistor network. Leave pin number 10 disconnected (fill it with solder).
#5 5 years ago
Thanks for the clarification.
Lighting - Backbox
Twisted Tokens
2,550 (OBO)
Bethlehem, PA
$ 29.95
PinBoss Mods
$ 36.95
$ 18.00
$ 2.50
$ 69.00
Pinball Pimp
3,152 (OBO)
Pulaski, PA
2,800
West Chester, PA
4,800 (Firm)
Kingston, OK
$ 35.99
$ 39.99
$ 65.00
$ 18.95
$ 175.00
Professor Pinball
This page was printed from https://pinside.com/pinball/forum/topic/sys-11-component-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
