This is my first post and i'm new to pinball repair so thank you in advance for your patience and help.
I'm having a problem with my xwing that I haven't seen posted yet. I just bought SWT in pretty good condition but with known malfunctions and thought I could repair with a little help. So far it's going well, but I was needing someone with the pin to help me out. When I got the machine there was a malfunction with the Bottom VUK. It fired repeatedly when machine was turned on and randomly during the game and the adjacent Reed switch seemed to be broken as well. Short story version, the Reed switch was reversed (magnet at bottom rather than top) resulting in not the switch not working and I presume the firing of the coil as a result by somehow also making it seem as if there was a ball stuck. Anyway, all the problems with the bottom VUK stopped when I reversed it. So regarding the xwing, the green wire to the Reed switch was broken but the xwing seemed to function fairly well otherwise. I almost left it disconnected but it seemed like the magnet diverter into the xwing was not timing correctly and the ball would sometimes pass on a second attempt at multiball or atat walkers. So I soldered it. Now when I turn on the machine, the xwing rotates and the coil fires until I start a game. It also fires a few extra times and rotates after it is loaded and fired too. It seems to be similar to the issues with the bottom VUK, so I'm thinking the Reed switch is reversed here as well. The problem is that the Reed switch is riveted on so it is not a simple take it off and put it back on and Idon't want to risk any damage if this is not the problem. So when I put a piece of metal in the xwing cannon frame welded assay, the switch activates when the metal is closest to the coil side of the reed switch as opposed to the side that is closer to the entry ramp which tells me the magnet of the switch is closer to the coil. As another point of reference, the green and grey wire enter the Reed switch on the side of the playfield rather than the side of the ramp passing to the inlane. Could someone please test your reed switch and tell me were the magnet part of the reed switch is located, closer to the coil or the entry ramp? If my reed switch is oriented correctly, does anyone have any other thoughts of what could be making the coil fire now that the Reed switch is fixed?
