(Topic ID: 327142)
Swords Of Fury Upper Diverter
By tcw16505
1 year ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by tcw16505
#1 1 year ago
Hello,
I trying to help a friend out with a couple of games. This one, Swords Of Fury, has what might be a switch problem. The Upper Ball Diverter (Sol. #19, Sol. Type: Special #3), which as it says diverts the ball to the mini playfield. In solenoid test mode it does not fire as the lower diverter does, however if I force Q73 by grounding the thermal pad on the transistor it fires.
I thought it strange that Q73 didn't work in test the position assuming the test signal comes from the CPU board (Rotten Dog) the board where the Q73 is located.
Thanks guys, Tom
#2 1 year ago
Sounds like Q73 is bad, I'd also change the pre-drive transistor for it at the same time.
#3 1 year ago
Quoted from Knxwledge:
Thanks for the reply. I'm not sure about Q73, it will fire if grounded but I will check B-E-C for an open or failed state. Its a non OEM board from Rotten Dog so it has no "pre-drive" transistor per say but a 74HCT08 Quad 2-input AND gate. - Tom
#4 1 year ago
Quoted from tcw16505:
If you can get the coil to fire by grounding the transistor that shows your wiring and coil are good, but does not mean the transistor is good. Id start with changing Q73, I personally wouldnt even bother checking if it's bad.
1 month later
#5 1 year ago
I'll se if I have one or order the transistor. 20N10L Transistor ~ TO-220 package, 100 volt 28 amp , IRL540 Replaces 20N10L.
4 weeks later
#6 1 year ago
Received it yesterday. I removed the old one and it tested OK. I will install the new one and test it later today. The diverter Solenoid is listed as a Special Solenoid. So it doesn't say what causes it to conduct.
#7 1 year ago
Remember, this is a MOSFET...they are funky to test...you can test the resistor and the SIP as well for the correct impedance....looking at the schematics...
Matt
#8 1 year ago
#9 1 year ago
I installed the new one and as expected when finding the old one good, nothing changed.
I had a spare board also arrive this week and dropped it in and yes it works perfectly.
I am going to take a probe to U11, pin 5 (2Y3) of the 74HCT240 and see what's up there compared to the reading taken on new board. Also U45B pin 3 of the 74HCT08. Based on the schematic I posted earlier I think there is a likelihood that one of these is the issue. Otherwise I suppose its whatever supports the AND gate at U45B.
$ 95.00
Pinball Mod Co.
$ 19.95
4,200
Birdsboro, PA
$ 170.00
Displays
Digipinball Shop
Trade
$ 69.00
Pinball Pimp
$ 27.00
$ 1.00
Pinball Alley
Apparel - Unisex
The GameRoom Store
$ 18.95
4,499
West Chicago, IL
$ 36.95
$ 12.50
RoyGBev Pinball
$ 27.00
