(Topic ID: 231651)
Swords of Fury Playfield Lights
By Man314
5 months ago
  • 17 posts
  • 7 Pinsiders participating
  • Latest reply 27 days ago by Willillist
There have been 15 images uploaded to this topic. (View topic image gallery).
#1 5 months ago
In ‘93 my wife bought me a Williams 1988 Swords of Fury. I brought it back to life years ago. It’s a fun machine. It has sat for 10 years or so and I decided to get everything going back to her former glory.
I replaced lower flipper mechanisms and coils, new silicone bumpers, replaced a few bulbs that were out, and found a bad fuse that was causing RH GI to be out. My wife and I have been playing this for a few days and we have fallen back in love with the game. We have a big Christmas party this Sunday which was spurring us to getting this all fixed up.
All was good until this morning. GI lights work but lower and upper playfield lights are all out. I have checked all fuses with continuity tester, I replaced a few fuses that were incorrect with new correct amperage fuses. Been like that since I’ve had it. No burned or disconnected electrical connectors. No loose or cracked wires.
Any ideas on where to go from here? I’m hoping it’s easy as I need to get this bad girl going by Sun. Any help would be appreciated!
#2 5 months ago
I would start by testing continuity all the way from the backbox to the playfield lights and back the other way. Don't forget to test across the GI relay as it's possible for them to go bad. Also, check for voltage - AC, not DC - in the playfield GI circuit.
#3 5 months ago
I think I know what to do to check continuity. I’ll check the relay, but it it went bad, would all GI lights go out? All of my General Illumination lights are on, it’s just the lower and upper playfield that is out.
As far as voltage, I’m out of my league. What voltage am I looking for where? Something happened to knock all playfield out at once. It’s not a single light or area. Looking to try to leverage someone’s experience with the upper 80s Williams machines. I can post pics or schematics if that will help. I’m just a newbie trying to get this thing going.
Thx
#4 5 months ago
There are two relays, one for the backbox GI and one for playfield. The playfield GI relay (if I recall correctly) is on a small circuit board (about 2" x 2") under the playfield near the back.
GI bulbs run on 6.3V AC. You could try pulling the GI connector in the backbox - I believe it'll be labeled on the bottom circuit board - and testing the header pins with your meter.
#5 5 months ago
Did you pull the fuses off the board when you tested them? You can get a false positive if you test a bad fuse when it is installed on the board.
#6 5 months ago
Quoted from Man314:
Are you talking about the feature lights under the inserts?
Could be a cracked solder joint on a ground pin???
Did the temp change where the game is because of cold weather? The change of temp makes electronics do weird stuff sometimes in my experience. Try turning the game on and leaving it on for a while to see if things start working after the game warms up
#7 5 months ago
Kelly
I’ll check the relays as you mention. Are the playfield and GI lights all tied together or on separate circuits? In other words does that relay work for both GI and playfield
JP
Yes, I pulled and used continuity setting on my DMM. I had a few fuses that the tone was somewhat intermittent. I did read up on slow blow fuses and evidently the older ones can test OK but not pass the right amps. I replaced those.
Chosen
Im talking about the feature / scoring lights under the playfield. The general illumination lights that stay on on playfield and backboard all work. I was wondering about an issue with a common ground being bad. Where would I look for this? How can I test to see if this is the case? No, temp has remained constant and no physical stress to the machine.
#8 5 months ago
Thanks everyone for your help so far . . . Here is a status and some new findings:
- Continuity on all GI and flasher lights on playfield and backboard are obviously good. Rechecked continuity at all fuses and they are good (except one, get to that later). Continuity on all playfield scoring lights, bonus, etc is not good on all individual lights when I went from one wire to next. I even pulled out the bulbs in case a sharp voltage spike took them all out . . . Interesting that the bulb continuity checks for the press in peanut bulbs mounted in sockets on small boards seemed to be good . . . I was checking soldered flat from one of bulb to other.
- Something strange is going on. My scoring LED panel is now out and my 1/4 Amp slow blow is blowing. I can only find 1/3 amp fast and 1/2 amp SB. I’ve popped 3 of these. I even tried a 2 amp SB for a few seconds and it blew that. I’m getting 96 volts across the fuse holders. May this be part of my problem?
My machine is now running, without scoring LEDs, without the 1/4 Fuse on power supply board, and without lights on playfield. If any of this helps narrow down a potential solution, I’m all ears
I did find the solenoid under the playfield at the bottom. Unsure how to test continuity or voltage. Pls advise.
#9 5 months ago
Here are some pics that might help
1D228CA9-4572-42DE-8E9F-90C6B0D254CE (resized).jpeg45D14846-AD77-45A7-BCF1-E24ED206C882 (resized).jpeg49B06E10-127F-4E65-B11B-CEEF1D3528FF (resized).jpeg5426AA88-15EA-4A42-A5FB-249B93E42736 (resized).jpeg57BA8FDB-9384-44E8-A78A-4CC7EBED014C (resized).jpeg593CE3BC-6C20-4255-937D-2BEE25EB0A44 (resized).jpeg5B325539-D2FD-48EA-9FED-69D0FCE35C7D (resized).jpeg940E4B8D-2C15-4657-8E2A-EF7F085CB2EF (resized).jpegA8975CCC-36DD-4AB8-AFE7-0291CC28C11A (resized).jpegB71FC70C-2DB1-4338-B868-42430A40B7AC (resized).jpegC5AF88AD-2FCE-4A56-B7E3-93C471DADC90 (resized).jpegE35CA50B-5791-47CD-9424-8AB429823208 (resized).jpegE4E9DC3D-71CB-4923-81F9-0306D9C17B68 (resized).jpeg
#10 5 months ago
So I removed the relay that controls light from the bottom of the playfield. Not knowing how to test continuity of a relay, I removed it and touched one probe to each pin location then to each soldered in penetration on the bottom of the circuit board. I was able to get 1-2 or 3 circuits connection for each pin (so there were some combinations of pins / relay penetrations that worked for every pin)
Don’t know if that means anything. Nothing looks burnt or even discolored.
#11 5 months ago
I think it would be worth testing voltages on the power supply board. If i understand your previous comment the alpha numeric display is now out as well?
To test DC voltage - set meter on DC and hold the black lead to ground and the red lead on the test point. Game power needs to be on. So take care with those leads in there
#12 5 months ago
It’s possible I fried the alpha numeric display swapping fuses. I didn’t have any 1/4 amp slow blow so I used a 2 amp SB. I know that’s a no-no but I was desperate to see if that fuse was the culprit to my lights being out. The display was working up to that point. Possibly unrelated. Maybe tied. Who knows.
How and where would I start looking for a grounding issue. That seems like a potentially logical as any place to go on this since the relays look good
1 month later
#13 3 months ago
I got the playfield lights going. Yay! Now to tackle the scoreboard. I traced power coming into board and I do have power. Thinking the board could be fried?? Just as a precaution, I bought another replacement scoreboard. Hopefully it will take care of it.
In a possibly unrelated manner, I still have fuses instantly blowing see pictures. .25 AMP slo blow. I tried a .5 AMP and a 2 AMP. They all blew. What could be causing this? What is this fuse for? I get 93.7 v AC and 12.7 milivolts DC with no fuse in it.
As you can tell, I can use any advice I can get. We have one local guy who services machines. He’s said he was going to come out since before Christmas.
758358EE-B552-446D-978C-99145EB86A32 (resized).jpeg4966C148-7D79-4FE9-A35A-6C3206A81E31 (resized).jpeg
#14 3 months ago
New board came in today. Had it installed in 3 minutes and viola, my Pin is back to its original glory. I kinda like that this replacement board has a variable brightness.
Still don’t know what that empty fuse is on the power board. At 1/4 amp it can’t be controlling much. Everything is working, so I’m not too worried.
#15 3 months ago
Quoted from Man314:
Those fuses were for the high voltage for the old plasma displays. Either there was a short in one of the display glasses or (more likely) the high voltage section itself had a shorted component. Either way, since you replaced with a LED display that does not use high voltage, you can safely remove those fuses and leave them out.
Kevin
#16 3 months ago
Quoted from Kevkat:
Kevin
Awesome . . . Mystery solved! Thx
2 months later
#17 27 days ago
So I’m having a similar issue how did you fix the light under the playfield??
$ 19.95
