Right flipper(s) blowing 2A slo blo fuse after a game or two. Resistance in the 5 ohm range and matches closely the left coils. EOS switch opens. My question is: if a diode at the coil is shorted or open could that blow the fuse? If so, why doesn't it do it immediately?
What's odd about this problem, this is a recent buy and I went through the fuses to make sure they were the correct value even though I had been playing the game for a few days. When I took that particular fuse out the end separated from the glass so I had a 2A Slo Blo fuse on hand, it was the old spring style fuse. It blew, when I used the more common slo blo I assumed it would be fine. But not so. As I write this, just discovered the rubber attached to the EOS arm was slightly worn and showed continuity to the shaft bracket when the flipper is actuated. Will fix this, however, that assy is not grounded and can't see why that would blow a fuse...
