(Topic ID: 318360)
Switch Stack Problem GTB
By undrdog
1 year ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by Peruman
    #1 1 year ago
    This relay has two stacked switches.
    The leafs of the top switch are two sandwich boards apart. Although clearly not closed, the switch reads as closed testing from lug to lug on the multimeter.
    The only thing I can think of is that they are connected through the screws. The only stacks I've taken apart were Wms, which had plastic insulating tubes, so if Gtb is the same, it can't be the screws.
    I'd appreciate some guidance before I take the relay apart probably for nothing.
    thanks!
    -undr
    #2 1 year ago
    If you think it’s a screw, take one out at a time, and measure resistance.
    #3 1 year ago
    More likely there's a nonobvious path through other parts of the game. For a reliable test of continuity, unsolder at least one of the wires.
    #4 1 year ago
    Quoted from HowardR:
    Yeah you can never really trust a continuity test that comes back positive on an EM. Not to mention that many meters treat even 10-20 ohms as 'continuity' when most coils in an EM measure less than that
    #5 1 year ago
    See, I know just enough to confuse myself. Thanks very much for the tips!
    -undr
    #6 1 year ago
    Hard to tell but just a thought…looking at your picture I don’t see the side of the top blade closest to the wire as I do the rest of the blades in the stack. Could be something, could be nothing.
    #7 1 year ago
    I’ll loosen he screws and make sure the switches are all lined up.
    #8 1 year ago
    Which relay is it on your schematic? In many Gottliebs, there will be an open switch and a closed switch from another relay in parallel with each other, making it so that the multimeter will read them as a short
    Alberto
    This page was printed from https://pinside.com/pinball/forum/topic/switch-stack-problem-gtb and we tried optimising it for printing. Some page elements may have been deliberately hidden.
