Bally Flip Flop 10 Point, 100 Point, 1000 Point relay switches located in backbox are not mounted firmly to the board like all the other relays. Instead these three relay/switches have a rubber grommet spaced between the board and the metal housing of the relay. These relays are flimsy and feel loose enough to fall off the board (but they are attached). What is the purpose of this and why only on these particular relays? I also discovered this method of flimsy fastening on the two Coin Chute relay/switches.
