Here is a question that will drive you crazy...
Here is a question th... sqeeezzzz ... yeah ... I know ... sorry !!!
Anyway - been ripping my hair off trying to figure out what's going on here.
Working on a Pinbot. It has 5 top targets. first, second and five work. But tree and four does not work.
They are all strobed through J8 pin 4. Tree is returned to J10 pin 3 and four is returned to J10 pin 2.
All 5 top targets are sequential starting with switch 28 for target 1, 29 for taget 2, 30 for target 3 and so on.
They are wired through a 6 leg connector with one pin being the strobe and the remaining 5 are returns.
I took the connector apart and used a meter in diode mode with one led on the strobe and tested each target. When activating the target switch I could see that the signal was returned to the meter. So - all target switches work.
I then took the connector of the MPU and tested for continuity from J8 pin 4 to the strobe pin in the 6 leg target connector. It's fine !
So conclusion is that strobe wire is ok. I should add that target 5 is last switch on the strobe.
I then thought I would concentrate on just target 4 which is in row 7. This is connected through J10 pin 2 (white / violet wire).
Looking at the switch matrix row 7 will start with slam tilt on switch 7 and end with switch 55 right sling. (Switch 63 is not used).
I measured continuity from J10 pin 2 to switch 55 right sling !!
Again - conclusion must be that the wire is fine.
Now - my question is - how can the strobe and return both be fine all the way through when target 4 is not working. And keep in mind the physical switch for target 4 is also ok ?!?
Only thing I can think of - and that I didn't test - is signal level of the strobe. But then again - if strobe signal is weak - why is it returned fine on target one, two and five?
As said - here is a question that wi..... (slam !)
