I'm hoping folks can chip in here on helping diagnosing a switch matrix issue and what I suspect is a blown diode (note nothing was changed and this was working just two days ago). Here is the run down on symptoms:
* When a ball is in the shooter lane the right sling solenoid fires.
* During a single switch test if the shooter lane switch is pressed the right sling solenoid fires.
* If the ball is resting on the shooter lane switch and certain other switches are pressed the sling solenoid will fire (specifically the coin door menu switches).
I'm suspecting that this is a diode issue because the right sling switch is one above the shooter lane switch. shooter lane is #53 and the sling is #52. I believe that would mean that the diode for the shooter lane switch is the likely culpret, but wanted to check with the forum if I should be doing some other testing or if I'm off base. Let me know. Thanks!!!
