I have a Williams comet, and am having an issue with a switch. I only got this pinball a week now and have repaired a few items and it was working ok.
Just now a problem came up that I didn't have before. When the ball activates the comet ramp upper switch (at the end of the ramp) the machine also think the outlane switch is activated (I think the right outlane). When I keep the switch of the right outlane activated the switch of the comet upper ramp works fine.
I disconnected J8 and J10 and when I connect J8-4 and J10-6 (the comet ramp upper) pins all works fine so it seems to be in the switches/wiring.
The reverse is not the case, so when activating the right outlane, the comet ramp upper switch does not get activated.
I don't fully understand the working of the switch matrix and how the diodes come into play, but I measured the diodes in circuit and they seem to be ok. There also doesn't seem to be a short, but the switches are connected right after each other.
Any suggestions are more than welcome!
