My SWE1 came with a nonworking Light Saber, so I set about making a new one. Here’s a pic of the end result - my iPhone couldn’t capture the deep bright green, but trust me, it looks perfect!
I started with this green LED rope, which has a nice even light distribution:
https://www.amazon.com/Lamomo-Flexible-Waterproof-Silicone-Decoration/dp/B08SJCFFFS
Any LED strip that runs on 12VDC will work. This one uses 800 mA per meter, so we’re at a bit over half an amp.
My game came with a 1” green acrylic tube. I fed the LED rope into it and saw 3 issues: it wasn’t straight, it was too bright, and it wasn’t diffused enough for me. I started shopping for frosted plastic tubes on Amazon, and a light bulb came on: the cheap LED replacement tubes at Home Depot use frosted plastic tubes. I bought the the 46” Phillips T5 tube, which is 5/8” in diameter. As luck would have it, the LED rope fit in it perfectly and the tube held the rope straight. This is what it looked like when I used my hacksaw on it:
Next, I fed the LED rope into the T5 tube, and used some foam to center the T5 tube in the 1” tube that came with my game. Is everyone’s tube green?
After reassembling the light saber, all that’s left is wiring. I connected the red (positive) wire to the game’s grey-yellow wire, and the black wire to the game’s brown-white wire (“solenoid” 41). I love that the light saber stays on for attract mode, but is used strategically in the game. I think it would be too bright if it was on all the time.
I hope this helps someone whose neon is out or missing. I’m really happy with the result.
