(Topic ID: 246906)
Sweet Hearts does not start up
By Milwaukee_Braves
-1
#1 4 years ago
My Sweet Hearts pinball does not start up. When the replay button on the front door is pushed, only the 'S' relay (start RE) makes. The score motor does not turn. All the fuses are good, the S relay contacts have been cleaned, and the game is set on free play. Any suggestions are greatly appreciated.
#2 4 years ago
Similar thread a day or two ago with a Buckaroo. If you start the score motor by hand does it complete the 120 degree cycle? if not no 24v feed.
#3 4 years ago
If you look on the schematic you posted on the right hand side just below “bank setup” you will see “ on ball release”. If you lift your playfield and look at the coil that releases the balls there should be 3 sets of switches it activates. The middle set controls the startup. Make sure that they are closed and clean.
#4 4 years ago
Quoted from pinhead52:
You nailed it pinhead52! The 24V line had an open circuit. Thanks a million! I'm a novice and would have been looking in the wrong places for the fix if you hadn't pointed me in the right direction. From one Texan to another--thanks again!
#5 4 years ago
Hi Milwaukee_Braves
in a german forum on another problem somebody showed a link to an Australian site - I had a look at the site --- maybe this (rubber chart) is of interest for You: https://www.pinballaustralia.com/scans7H.htm Greetings Rolf
Cabinet Parts
Cabinet Parts
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/sweet-hearts-does-not-start-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
