(Topic ID: 290106)
Suzo-Happ coin door bolt size? (Dialed In)
By fossmin
1 year ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by fossmin
    #1 1 year ago
    I am trying to remove the hardware from my Dialed In coin door to get it powder coated. Anyone know the size of these bolts I have circled in red? I can't seem to get anything that wants to work. There are a bunch of them holding the coin mechs on.
    #2 1 year ago
    I just checked my Wonka and they are 3/16”. I changed my left coin slot to a dollar and had to file the plastic down so dollar coins would fit. I used a Wiha nut driver as some of the screws were driven below the surface of the plastic and it was small enough to fit and still rotate the screw. Here is a link to the nut driver I used: https://www.wihatools.com/precision-nut-driver-3-16-x-60mm-6341
    #3 1 year ago
    Yes, a 3/16" nutdriver works, but it must be in good condition. The factory over-tightens those screws so they sink deeper into the plastic. This makes it harder for the nutdriver to grip the screws.
    #4 1 year ago
    Thanks guys. I tried a 3/16 put couldn't get it to grab. I will try another one.
    #5 1 year ago
    Quoted from RellikJM:
    I ordered and used this Wiha nut driver and it worked perfect. Nothing I had would work and my regular sockets would never get between the two coin mechs in that tight space.
    Thanks for the tip.
