(Topic ID: 186565)
"Surfin the Tube" Club (Surf Champ, Surfer, surfing Pinballs)
By swinks
  • 101 posts
  • 36 Pinsiders participating
  • Latest reply 31 days ago by luckycreature
  • Topic is favorited by 20 Pinsiders
There have been 77 images uploaded to this topic. (View topic image gallery).
There are 101 posts in this topic. You are on page 2 of 3.
#51 1 year ago
My Surfer developed an Issue. it scores 2X bonus when it should be 1X. It scores @X and 3X correctly when lit.
Where do I start?
#52 1 year ago
Quoted from bob_e:
Where do I start?
My guess (and my knowledge is limited) would be the stepper unit that controls the bonus under the playfield needs adjustment. Lift the playfield and turn the pin on. Start a game and then press the rollover stars one at a time to see if then are working properly.
#53 1 year ago
Alright, so here's my obvious first problem;
This is the main primary fuse for the game. Surprisingly, it still passes a connectivity test. Yet another reason why you should always remove fuses when testing them. It came out of this;
Lots of corrosion. I'm surprised that the game was lighting up at all. I will be ordering fuses and fuse holders tomorrow. Is there anyone that can confirm the fuse values for me? I can't tell if the primary is suppose to be a 5A slo-blo or if it's a 15A slo-blo as my signage is torn/ripped.
As far as I can tell there are only 6 fuses in the entire game;
Primary Fuse: 5A slo-blo (need confirmation)
25V Fuse: 15A
Playboard Light: 10A
Lightbox: 10A
Under the playfield...
2A slo-blo
1A slo-blo
I take it these fuses are all supposed to be 120-125V? Are they all supposed to be slo-blo? Does anyone have the proper list of fuses for this game?
#54 1 year ago
Alright, fuses and fuse holders ordered. For future reference;
Surfer Fuses
Primary Fuse is a 5A slo-blo
25V Fuse is a 15A fast
Playboard Light Fuse is a 10A fast
Lightbox Light Fuse is a 10A fast
Sequence Bank Reset is a 1A slo-blo
Target Bank Reset is a 2A slo-blo
#55 1 year ago
Surf Champ Questions
1. On each ball does the light for the top lane bonus always reset to the far left?
2. When you go through the top lanes ( not lit) does it add 1K on the bonus?
Clive
#56 1 year ago
1) Yes, as pictured.
2) Yes
#57 1 year ago
1967 Bally Surfers. . .one of my summer restorations. First class geometry on this Ted Zale designed zipper flipper masterpiece. Apart from zipper flippers, features include left outlane kick-back, right outlane ball-save gate, perfectly positioned 3rd flipper, carryover bonus, two kick-out saucers. . .phenomenal ball flow and fast action throughout the playfield.
Jerry Kelley's best art package on this title, in my view. Check out the mischievous pelican on the playfield and backglass.
I like Surfers every bit as much as my Surf Champ. . .actually, more so.
20181102_204315 (resized).jpg20181102_204341 (resized).jpg20181102_204402 (resized).jpg20181102_204422 (resized).jpg20181102_204514 (resized).jpg
#58 1 year ago
Here's a shot of the Surfers cabinet. Typical degraded Bally paint from that era which required touch-ups and sealing.
#59 1 year ago
Quoted from ZNET:
1967 Bally Surfers
I want one!
#60 1 year ago
znet looks really nice!
#61 1 year ago
I replaced the primary 5V slo-blo fuse and holder today. I knew this wasn't going to be a 'magical' fix but I had to start somewhere.
I powered on the machine and started poking around the transformer. Right now I'm only seeing 55V off the transformer which sucks. It seemed like I'm not getting a proper ground for my DMM so I decided to test connectivity on the power cord. Connectivity was good on the black and white wiring, but the ground (which is cut off on the plug end) was obviously not good. There was still a bit of a numb on the plug that I thought would work for tone but it didn't which I found strange. I have a new power cord on order with PBR so I'll replace it once it arrives.
Back to the transformer. I know it is ugly looking right now, but if you can ignore it's looks and just take a look at the wiring for me I would really appreciate it. The red wire is on the HIGH tap. I get 120V+ in my house so I'll be moving it over to the NORMAL tap one I confirm the voltages with the new power cord. Are the rest of the wires in the appropriate spots? I have a manual, so I'll start digging, but I thought I would ask here too because it keeps the discussion in this thread alive and it's often better to hear from someone with experience.
Thank you!
#62 1 year ago
Slow thread...
I wasn't getting a solid ground at my transformer. The old cord was in pretty bad shape. See for yourself;
Luckily, I received my Digikey and PBR goodies today. I wanted a hard copy of the schematics and manual so I order a bunch of other items at the same time. One of them just happened to be a new line cord.
The manual was $4 and the schematic was $16.50. The schematic is worth it's weight in gold, and the manual is uh... Well, it's worth $4.
#63 1 year ago
After searching for a long while, and with some amazing work and help from a kind pinsider, Surfer now lives in my friends surf shop in Maine. We surf all winter here, and there is no better way to warm up after spending a couple hours in the Atlantic surfing a nor’easter than flipping for that triple bonus on your last ball back at the shop.
#64 1 year ago
Hi guys, I need some help confirming the contacts on some of the relays inside a Surfer pin. Specificially Q, U, V, and H. The previous owner of mine has moved the relays around. For example, I am looking at the schematics and they state V should be 1 contact, but I have 5 wires going to my V relay.
I believe that 1 contact should only be two wires. 2 for open/closed, 3 for make-break.
How many wires are connected to your V relay on Surfer?
Added 17 months ago:
Solved.
#65 1 year ago
I m working on a nice "Surf Side" with a "Surf champ" behind...
#66 1 year ago
off topic but cool, latest artifical wave maker
2 months later
#68 1 year ago
Quick question about Surfer/Surf Champ. I have my pin working now (woohoo) but I am not use to the scoring. When the ball rolls over any one of the 4 switch lanes on the upper playfield should it award 400 or 500 points? I'm only getting 400. Thanks!
FYI... I am going to have more scoring questions I'm sure.
#69 1 year ago
swinks (et all) I am having some difficulties with my Surfer. I need some clarification of how the bonus works and I have a question about the bonus stepper.
1) How does the x2 and x3 bonus work? When are these suppose to light?
2) For the bonus. With the glass off, if I press the rollover on the far left I score 500 points on the score reels and 1000 in bonus. I press it again I get another 500 on the score reels and another 1000 bonus. If I keep pressing down this rollover I eventually get to 14,000 in bonus. If I press it again my bonus does not count up to 15,000. On the bonus stepper under the PF, I noticed it has a notch in it. It looks like it is missing a tooth on the gear, but I am thinking it is factory like this. This missing tooth is the reason why my bonus doesn't increment to 15,000.
Here is a picture. Right now I have 14,000 in bonus lit but I can't get 15,000 because of this missing tooth. Is there a tooth missing on your game? Am I missing a tooth or is this normal? It is very clean looking so it makes me think it is supposed to be this way.
#70 1 year ago
Hey fifty, unfortunately my game has been in storage for years so technically can't help but maybe able to get to it and confirm visually about the gear tooth
#71 1 year ago
In with my Surfers!
E97EC57E-748B-432E-8A15-2CE8D7607AA2 (resized).jpeg3F8909EC-A4AD-4C56-8D39-061ADC453E68 (resized).jpegA0D119F5-198A-49B6-8F79-4B91A0FD9B5F (resized).jpeg
#73 1 year ago
Hey fifty , I remembered a have a almost full kit of surfer backbox mechs in the garage as going to make a surfer backbox one day.
Is this the same gear with other parts fitted? if so, there is no missing teeth on the metal gear, that in theory would suggest that it would then foul with the mechanical operation and scoring
#74 1 year ago
found this on a net search, though doesn't show the gear by inself
https://www.flippers.com/gott-sub-assemblies.html
#75 1 year ago
Quoted from swinks:
No this is a different gear.
Quoted from swinks:
Not this one either. It's the bonus stepper under the playfield.
I think the tooth is supposed to be missing. See this pic (highlighted with a yellow circle);
I need to focus on one thing at a time, so I'll focus on the bonus stepper first. Mine counts up to 14,000 and then stops because it gets to the gap in the gear (where I thought a tooth was missing). Is this normal?
#76 1 year ago
Alright, it seems 15,000 is the max for the bonus. I found this nugget of info in Bob's Guide To Playing EM's;
"Top lanes and upper left lane advance bonus, maxes at 15,000."
So it seems my bonus is working. Looks like it might be misfiring or skipping, but that is probably just a clean up job or alignment issue. Good. So my bonus stepper is in one piece and functioning correctly. It just needs to be fine tuned.
2X bonus = get all the red star rollover switches. Then get one of the middle rollover switches (green lights). 3X is the same but only works on last ball.
4 months later
#77 1 year ago
copied from pinballsupernova is this cool mod for a Surf Champ - music and a video mode
#78 1 year ago
Quoted from swinks:
This is awesome! Thanks for posting!
#79 1 year ago
My Surf Champ is for sale in Chicago: https://pinside.com/pinball/market/classifieds/ad/82851
#80 1 year ago
I need this mod as it is truly AWESOME
#81 1 year ago
Picking up a surf champ tomorrow morning. Not sure if it works or not. For $200 who cares.
#82 11 months ago
Quoted from swinks:
One could also rename it as “ surf circus “ ...
#83 11 months ago
I am having a heck of time getting my surf champ going. Score motor constantly runs at power on, went through all the obvious things and it still runs and now F2 in the back box constantly fires now. Cleaned everything and went through all switches.
#84 11 months ago
Hey! New to the club as well with a Surfer acquisition. Hoping woody76 gets an answer as I'm having similar issues at power up where the score motor starts running instantly.
woody76 Maybe we need a Tech post for it - this thread doesn't seem super active?
#85 11 months ago
Quoted from woody76:
Maybe one of these threads gives you a new starting point to investigate?
https://pinside.com/pinball/forum/topic/gottlieb-surfer-1976-game-runs-constantly-at-power-up
https://pinside.com/pinball/forum/topic/1976-gottliebs-surfer-start-up-problems#post-3918519
#86 11 months ago
My game over relay stays energized. I assume that should not be? My score motor constantly runs at start up. I have no schematics.
#87 11 months ago
Not sure, I don't have schematics either. Best bet would be to try a new EM Tech Help thread as that will probably be seen by a larger audience.
3 weeks later
#88 10 months ago
Usually is due to score reels not resetting to zero. Check your backbox for any relay that keeps clicking. Try and clean all the relays inside the back box if possible .
3 months later
#89 7 months ago
Well DING DANG got to play this absolute beauty today and I want one baaaaaaaaad! best retheme and art package EVER!Can you guess the original game?
1 month later
#90 6 months ago
lots of surf champ parts still left if anyone needs something
#91 6 months ago
Quoted from oldskool1969:
Well DING DANG got to play this absolute beauty today and I want one baaaaaaaaad! best retheme and art package EVER!Can you guess the original game?[quoted image][quoted image][quoted image]
Beautiful re-theme and looks great! Nice to see Bally Eight Ball in a different style.
#92 6 months ago
Some of scottys best work right there
#93 6 months ago
I’ve had my surf champ about 5 years now.
It’s never leaving.
#94 5 months ago
I’ve been an eligible member for quite a while, but new to the club! Here’s my entries: a restored surf champ and a huo Hula that my wife’s grandma bought new.
AC8E95E2-EF75-4283-B35F-432543C79FD1 (resized).jpegFD56BAB7-CBB1-415C-82D0-3E1DDB9977F2 (resized).jpeg4B53E3F4-9150-4730-BA36-B15FAFA7834C (resized).jpegB02B8E44-D19B-44A5-A663-F1E3EB3A7F74 (resized).jpeg058C05A5-A643-4CFD-B4FF-5B4026191E55 (resized).jpegB2092416-C029-46A7-9493-15A1DCB1D5AE (resized).jpegFCDDC267-6753-4C39-9451-CBC0DB06FF78 (resized).jpegCBEE5A80-9BCA-4A4F-921E-0DC67871A66B (resized).jpeg
3 weeks later
#96 5 months ago
Just picked up today and working.
C0237124-0C80-4289-BA1E-AD5E32C7E9AC (resized).jpegF852F98F-B03C-4569-AA2F-DAE33FD544FA (resized).jpeg
#97 5 months ago
I love that backglass.
3 months later
#98 57 days ago
Really eager to acquire a Surfer!! Willing to pay a very fair price to get one.. based in Tahoe City, CA but willing to pay from shipping from anywhere in the US. Ideally working, but also open to restoring.. thanks!!
#99 57 days ago
Quoted from quicksilvr:
quicksilvr Cross country shipping, but a good price
newyork.craigslist.org link
#100 56 days ago
Quoted from steviechs:
Wow thanks!
€ 8.40
Gweem's Mods
$ 269.00
$ 249.00
$ 5.00
$ 7,599.00
Classic Game Rooms
$ 7,000.00
Arizona Pinball
$ 229.00
PinballBulbs
$ 5.00
Playfield - Plastics
Ramp-O-Matic
$ 139.95
$ 9.99
Bent Mods
