Something's been bugging me recently on my Surfer -- I'm wondering if my chimes are wired up incorrectly. It seems like it'd make sense to have 10 points as the small bar / high chime, 100 points as the middle bar / medium chime, and 1000 points as the long bar / low chime. However, mine has 10 points on the middle chime and 100 points on the small chime ... all the high pitch chiming (since most points on this game are awarded in hundreds) is getting to me! Just doesn't seem to make sense.
Should be easy enough to switch -- and I'm thinking I'm going to change it regardless. Should be super easy too since they're hooked up with spade connectors. Either way, though, I'm curious what order they're SUPPOSED to be. A similar question came up on a Bronco (ref https://pinside.com/pinball/forum/topic/gottlieb-bronco-chime-order ) and that one turned out to be the order-that-makes-sense -- 10/high, 100/med, 1000/low.
