(Topic ID: 230915)
Surf Champ , Slow , playfield restoration
By phototamer
8 months ago
  • 144 posts
  • 16 Pinsiders participating
  • Latest reply 7 days ago by phototamer
  • Topic is favorited by 19 Pinsiders
There have been 267 images uploaded to this topic. (View topic image gallery).
There are 144 posts in this topic. You are on page 3 of 3.
#101 24 days ago
The area that was sanded beyond the paint is corrected , along with other minor touch ups. The area is not visible to the player but I feel I need to correct every inch of the playfield , visible or not.
#102 24 days ago
When the final coat of clear is applied everything is going to "melt" together beautifully
I am not sure though how to proceed with the decals covering the star roll overs. One option is to leave them as they are so as to act as a barrier to the clearcoat , and cut the star hole with a xacto after the clear is cured. another option is to remove teh inside of the decal before clear coating and close the hole with some reversed plastic stars. I am leaning towards the second option .
_DSF4601 (resized).JPG_DSF4602 (resized).JPG_DSF4603 (resized).JPG_DSF4604 (resized).JPG
#103 24 days ago
It’s really looking great.
#104 23 days ago
Quoted from Silverstreak02:
Thank you
#105 23 days ago
Looks great, excited to see it with the final clear!
#106 23 days ago
looking awesome, great work
#107 23 days ago
Quoted from phototamer:
This is the method I TRY to remember to use!
#108 22 days ago
I feel bad for using terrible language, but I just can't think of another way to say it. F*#%king Fantastic.
fan·tas·tic
/fanˈtastik/
adjective
extraordinarily good or attractive.
"they did a fantastic job"
synonyms: tremendous, remarkable, great, terrific, enormous, huge, striking, impressive, outstanding, phenomenal, monumental, overwhelming
#109 22 days ago
Quoted from Atari_Daze:
I will sprinkle some old plastic stars on the playfield , hoping that I will remember to cover the star roll over holes this time !
#110 22 days ago
Quoted from xsvtoys:
fan·tas·tic
/fanˈtastik/
adjective
Ha ha .. This is so encouraging !!
#111 20 days ago
Ok , managed to print my color decals . and getting ready to see if the color is a good match ...
#112 20 days ago
Looks ok to my eyes. After putting the decal in place I noticed that there is a small gap all around the are. I will have to paint the area around the decal with matching red before putting the decal in place.
#113 20 days ago
Then I thought .. why dont you paint all the white are in red , so as to get a uniform color ? .. big mistake , since the decal is not totally opaque , so the red color shows through the white letters making them a bit pinkish.
this happens when you haste things !
#114 20 days ago
So , removed the center portion of red so as to make the white ... white again .
#115 20 days ago
Everything is ready for the final clear coat. Oops , almost forgot , again , to deal with the star roll over holes I decided to remove the center portion of the decal and cover the holes with some old plastic stars .
#116 20 days ago
The playfield is sitting in its case ready to be clear coated. I will also clear coat the side rails now that I have the chance.
#117 20 days ago
#118 20 days ago
The playfield is sitting in its case ready to be clear coated. I will also clear coat the side rails now that I have the chance.[quoted image][quoted image][quoted image]
Amazing job. I wish I had your skills!
#119 20 days ago
I had just enough clear coat for this time. Maybe a tad less that I would like , but today was the only day I could have done this and there was no way I could have gotten more clear. Guess I will have to be more prepared next time I will let the playfield sit 2 or 3 weeks and after block sanding with 600 grit sandpaper will decide if I will give it another final coat.
_DSF4624 (resized).JPG_DSF4622 (resized).JPG_DSF4625 (resized).JPG_DSF4626 (resized).JPG_DSF4627 (resized).JPG_DSF4628 (resized).JPG_DSF4629 (resized).JPG
#120 20 days ago
Quoted from PinJim:
You could do it too . You need patience and taking things step by step . you cannot rush it .
#121 20 days ago
Curious if you use the method Vid discusses where you dust over the final work with the clear twice (a few moments apart) to seal the waterslide decals then do a final thick coat or do you just give it a full coat?
I've done it with dust coats but have thought I would try and rush one time and do a full heavy coat.
#122 20 days ago
I've done it with dust coats but have thought I would try and rush one time and do a full heavey coat.
I do it the Vid Way. I "dust" once , wait for 15 minutes and then give another 2 light coats with the same 15 minute flash time in between. That way the clear cures better in my opinion. I bet is more secure to just bond the decals with the playfield before applying a wet coat. I dont think that the decals will melt and the toner spread around with a first wet coat , but better safe than sorry.
#123 20 days ago
I've followed this forum from the start. Wow what a amazing job. Can't wait to see it plugged in and lights on. Super Surf Champ
#124 17 days ago
Waiting for the clear to cure , it is a good time to try and restore the spinning target. The graphics are not perfect imo. I did order a complete set of decals for the apron , spinning target , and drop targets from Pinball Rescue. When they arrive I will compare them with my own. If they are better I will redo the drop targets and spinning target. To let the colors of the decals "shine" it is best to have a white surface for the decal to sit on. I tried to paint the metal surface white with a small brush , but the result was not good. I would have to do that with an airbrush to get the smooth and even color I was after.
#125 17 days ago
An easier , faster and cleaner method is to put an empty white decal on the metal surface so as to create a perfect surface for the actual color decal to sit on.
#126 17 days ago
Both decals applied on top of the white empty decal.
#127 17 days ago
To protect the surface from the multiple hits of the ball some people suggest to use Mylar. I found though that transparent packaging tape works beautifully on all sort of drop or spinning targets. Caution is needed when applying though , since the decal underneath is very sensitive and can break with the slightest attempt to lift the packaging tape to correct any mistake.
#128 17 days ago
Tape applied and target ready for battle
#129 17 days ago
#130 8 days ago
Decided to block sand with 400 grit , and make sure the playfield is flat, with a final clear coat. Photos taken just after the last clearcoat. This time I had the amount needed.
Will definitely leave it to cure for a couple of weeks before I block sand progressively to 2000 grit.
20190813_070444 (resized).jpg20190813_070502 (resized).jpg20190813_070555 (resized).jpg20190813_070947 (resized).jpg20190813_070623 (resized).jpg20190813_070902 (resized).jpg20190813_071001 (resized).jpg20190813_071027 (resized).jpg20190813_071058 (resized).jpg
#131 8 days ago
Since I do not have a rotisserie , I made one from scraps I had around , with the frame i use to clear the playfield. Consider this one a poor man's rotisserie
#132 8 days ago
Broomstick for the axles , pegs for stopping the rotation and 2 stands for... support.
Strengthening the hole that will support the playfield..
20190813_074919 (resized).jpg20190813_080001 (resized).jpg20190813_080007 (resized).jpg
#133 8 days ago
Creating the axles that the contraption will pivot on.
20190813_114814 (resized).jpg20190813_114819 (resized).jpg20190813_114827 (resized).jpg
#134 8 days ago
Placing some angle iron to hold the playfield.
20190813_084042 (resized).jpg20190813_084436 (resized).jpg20190813_084101 (resized).jpg20190813_084408 (resized).jpg
#135 8 days ago
Putting a stopper to each axle making sure the playfield stays put.
Works ok . Not very elegant but completely functional. Will add some pegs to be able to lock the playfield horizontally or vertically.
I only spent 8 dollars to make the 2 wooden supporting stands so I am happy with the result
20190813_125232 (resized).jpg20190813_125242 (resized).jpg20190813_130156 (resized).jpg20190813_130206 (resized).jpg20190813_131148 (resized).jpg20190813_125155 (resized).jpg20190813_125209 (resized).jpg
#136 7 days ago
I see you are working barefoot in the shop, just getting into the theme of the Pin, I guess
#137 7 days ago
Quoted from ReadyPO:
Here it is 40 Celsius . It is good that you can only see my feet and not my whole body
#138 7 days ago
The drop target assembly needs to be disassembled. Some people like to cut a way for the drop targets to be removed. I like to leave things as they are if I can.
Removing the targets is easy after all.
Back plate removed.
20190814_112543 (resized).jpg20190814_112956 (resized).jpg20190814_113005 (resized).jpg
#139 7 days ago
Lower plate removed revealing the way to remove the targets. Taking care not loose the springs is the only difficulty.
20190814_115128 (resized).jpg20190814_115226 (resized).jpg20190814_115254 (resized).jpg20190814_115309 (resized).jpg20190814_115323 (resized).jpg20190814_115915 (resized).jpg
#140 7 days ago
A bit of scrubbing and rubbing makes things much cleaner. For now I will clean and / or replace springs since the action is a bit lazy.
They look good enough . I do not have new white drop targets , I will have to wait to accumulate a bunch of things to order from Marco since shipping here is astronomical.
#141 7 days ago
I will try and superimpose the white decals on top of the original and see how they look.
#142 7 days ago
Awesome job! I can't wait to see it when you are finished.
Are you going to re-finish the cabinet too?
How's your backglass? Mine had significant flaking in the reds, so I got a repro from bgresto. It's very nice, but not as good as a screened glass. I haven't searched for a year or two to see if anyone made a re-screened glass. Seems like someone would, this title always seems to suffer from flaking in the reds.
Anyhow, following this thread. Nice work!
#143 7 days ago
Quoted from PinJim:
Thank you , fortunately my glass is in very good condition. As for the cabinet , I will make templates and restored it completely.
#144 7 days ago
I finished the drop targets . They are not perfect , but they are ok. I will use these until I manage to get new white drop targets.
€ 8.40
4,500
Shelburne Falls, MA
Trade
Machine - For Trade
South Harrison Township, NJ
$ 14.95
$ 2.00
Doc's Pinball Shop
$ 9.99
$ 28.00
$ 65.00
Texas Pinball
$ 149.00
$ 229.99
$ 48.00
$ 3.00
Doc's Pinball Shop
$ 48.00
$ 70.00
PinWorlds
$ 109.99
$ 76.95
Hookedonpinball.com
$ 36.99
Lee's Parts
$ 4.95
Apparel - Unisex
