So the other day I started up Surf Champ to play a few rounds before work and it went through what I thought was a normal startup but the third player Ten Thousands reel didn't reset to 0 and the Score Motor just continued to spin. I shut the machine off and reset the reel manually to 0 and made sure the AX was reset and turned the machine on again. This time it looked like a normal boot-up sequence and even ejected a ball. When I attempted to play nothing on the play-field registered a score and the flippers didn't work. All four players scores are 0 and the game ejects a ball but none of the playfield scores points.
Poking around in the head I found the following and assume this is my problem but not sure.
It looks like the wires broke but not sure if this is my problem. I have also never heard the knocker on this machine and verified it does have one so figured this could be why as well. The game was working before the other day (minus ever hearing the knocker)
I have had the machine for maybe 6 months so still learning about it. So first things first just wanted to get it back to playing and then I will investigate the knocker not knocking
