Quoted from Cruzin1a:OK that makes sense. So in the attached image The blue path comes from a switch in the "S" relay which is the path when the reset button is pressed to start a game. That path successfully advances and zero's the "Player Unit" as mentioned.
The green path, as highlighted by DirtFlipper was a path I should check because when the ball drains the machine doesn't advance to the next ball and does not advance the Player Unit.
I see many "NC" switches which the schematic describes as 1st, 2nd, 3rd and 4th player reset switches. I also see two "NC" switches shown in the "Z1" and "Z2" Relays involved.
I then see the Motor 1A "NO" switch. Is that Motor 1A "NO" switch my concern?
No, the switch at score motor position 1A must be working if the score reels are resetting and the player unit advances during that. And Z1 and Z2 also must be working if that's the case.
You want the path that I highlighted back here:
http://pinside.com/pinball/forum/topic/surf-champ-next-ball/page/2#post-1294058
Within that path, the switch at 1A is the one thing we know is working.
Coincidentally, I just fixed this exact same problem on another Gottlieb 4-player over the weekend for a friend of mine, and in that case it turned out to be the switch at score motor position 2C, which is the middle switch (third switch in the operator manual listing). It wasn't closing all the way, and took a good strong light to see it well enough (board was still in the game). But the path that has BX, P, 2C, U, and whatever that first NC switch is (F?) is the one you want. The problem lies with those. Score motor switch at 2C would be a good guess though.
