Hi joetechbob
I write the ruleset from my Surf Champ set to "5 balls per player / game". I write it in the succession You may check if Your pin is functioning complete.
In the first game I do NOT make all Drop-Down-Targets to drop (easyer to describe the functions). One of the lights "A B C D E" is lit --- the light may move to the left when the spinner (P) is actuated - when the pin steps after the loss of a ball - steps to next player / next ball. An unlit "ABCDE" gives 500 points and ONE Bonus, the lit one gives 500 points and TWO bonus.
In balls 1,2,3,4 - at the beginning of a ball: The "U" and the "V" are not lit --- when I play good I can make "double bonus - lighted U". When the pin gives the fifth ball: Automatically the "U double bonus)" is lit --- when I play good I can make "triple bonus - lighted V".
Still I do not make the Drop-Targets to drop --- at the beginning of every ball the "FGHIJ" are all lit - the "KLMNO" are all un-lit. When the ball lands in the Eject-Hole: A hundred points for every unlit "KLMNO" - a thousand points for every lit "KLMNO". When the ball rolls over (lets say) "F": The "F" changes from "lit" to "unlit" AND the "K" changes from un-lit to lit. Same with G-L, H-M, I-N, J-O.
AT THE MOMENT I make the last of the "FGHIJ": The green invitation lights "Q" and "R" are lit: HERE You can make DOUBLE Bonus (playing in ball 1,2,3,4 - the "U" lights up) - HERE You can make TRIPLE Bonus (playing ball 5 - "the light changes from "U to V"). The "Q" and the "R" always give 500 points and one bonus (lit or un-lit). Also at the moment I make the last of the "FGHIJ": The Spinner (P) is lit and changes from 10 points to 100 points.
I start the second game - this game I NEVER touch the "FGHIJ" - but I do make all Drop-Targets (12345) to drop - every hit Drop-Target gives 500 points and one bonus. When all Drop-Targets are down: They stay down --- until I loose the ball.
I start the third game - I first make the "FGHIJ" --- it does not matter if I make the bonus-multiplier --- then I make the targets to drop - at the time I let the last Drop-Target to drop: BINGO: I get 5000 Points AND all Drop-Targets RESET AND the "invitation-lite 'S' HERE You can make an Extraball" is lit - AND the "invitation-lite 'T' HERE You can make an Special-Replay" is lit. And I can make all drop-targets to drop - again 5000 points and the targets reset.
I start the fourth game - I first make ALL Drop-Targets to drop - they stay dropped - THEN I make the "FGHIJ" - BINGO: (Q and R are lighted and) I get 5000 Points AND all Drop-Targets RESET AND the "invitation-lite 'S' HERE You can make an Extraball" is lit - AND the "invitation-lite 'T' HERE You can make an Special-Replay" is lit. And I can make all drop-targets to drop - again 5000 points and the targets reset.
Whatever situation: The "rollover S and T" give 500 points plus one bonus. The INLANE rollover-wires next to the "S and T": Only give 500 points. Greetings Rolf
