I find this a bit embarrassing, I thought I had my process down – I have rebuilt a dozen or more steppers and as always I took a bunch of photos but somehow I have parts left over!!
Surf Champ / Bonus Unit – been in the project cue. Someone spent some time cleaning, polishing and over lubing with gobs of ?silicone?. The Bonus Unit gleams but was the main spring was solid as was other pivot points, nothing moved. Took it partially apart where needed, cleaned it up, put it back together and have the two pictured parts left over – a washer and a long thin black bolt. The unit seems to step up and down MANUALLY now, smooth action : ready to put back in the machine except I have these these leftovers!
Is there a washer between the two arms on the shoulder bolt? There is a similar washer on the pivot point of the horizontal arm along the bottom of the unit.
I don’t recall the black bolt at all – is it even a part of this stepper? Slightly smaller in diameter than those on the switch stack. Things do disappear on their own sometimes so I guess they could also just appear .
Prevegen: Yes or No - tho may need to sell a pin to fund. Yike$!
