(Topic ID: 214621)
Surf Champ
By Crjfan
6 years ago
  • 9 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by Crjfan
#1 6 years ago
I need some help getting a Surf Champ running again. Can sombody send me a copy/photo of the chart with the SCM switches?
#2 6 years ago
This is what you get with Gottlieb. If this doesn't help, post a description of the problem.
#3 6 years ago
I got a simple copy of the scematics, but inside the body the chart with the scm switches is missing... I need to find the scm switches for bonus score.
Everything is up and running but it doesn't give me 2X/3X bonus.
I checked the feature bank and the bonus unit and the bonus score relay. Couldn't find any Problem there.
#4 6 years ago
Hi Crjfan
greetings from Europe - Rolf
#5 6 years ago
Danke Rolf! Thx Howard!
#6 6 years ago
Hi Crjfan
I also have an Surf Champ - almost impossible to get to the Backbox - hard to get at the Bottom-Board - hard to get at the Playfield - especially "Sequence Bank".
Before I dig (deep) into my pin the questions: Is Your pin set to 3 Balls per game ? Set to 5 Balls per game ? My Surf Champ is set to 5 Balls per Game - when the pin kicks out the fifth ball (for player-1): Double-Bonus lights up --- in Your pin ?
See the JPG - Gottlieb uses an 6VAC-Coil on 11B (mounted in the Sequence Bank) --- some wires are involved - wires on the Adj-plug mounted on the left of the playfield.
As the 11B plunges: The 10B is made to plunge and so the Double Bonus light is lit. It is tricky to see the stuff in the Sequence Bank - as the Sequence Bank is resetted - resetted immediately before the 11B / 10B plunge - so I see the reset arm move - I do not see the 11B / 10B plunge --- well after I see them plunged.
Want to check wire-green, wire green-white, wire-white --- on the 3-5 Adj-plug on the playfield ? Greetings Rolf
#7 6 years ago
Hi Rolf!
My pin is set to 3balls.The game will give you 2x bonus on last ball. (3ball and 5ball)
#8 6 years ago
Hi Crjfan
I must ask when I am not sure if I do understand --- O.K., Your pin is set to 3 balls per game --- do YOU GET the double-bonus light (on the playfield) LIGHTED on the last ball ? You play the last ball - do YOU GET the bonus as "single" or as "double" or "no points to the Score drums - just the bonus-ladder is stepped down" ? Greetings Rolf
#9 6 years ago
The problem is solved. With your help guys I was able to find the right switches on the Scm. (Motor 3B/3C).The gap was not correct and therefore it didn't make good contact at both "Bonus score control switches".
2X / 3X bonus count without any problems during play and at the end of the last ball in play.
Greetings Niki
Herndon, VA
Space Coast Pinball
