I have a Sure Shot pinball that is now giving me problems after I replaced the flipper coils. Prior to replacing the flipper coils the issue was not present. I'm new to EM's so my troubleshooting abilities are very limited. I also don't have any schematics for this game, not that it matters because I still don't know how to read them quite yet.
Here is what happened. I replaced the left coil first, put the PF down, turned it on and tested the left flipper and this indeed fixed my weak flipper issue. Left flipper was now twice as strong as the right flipper. OK, no problem I thought, let's swap out the right flipper coil, which I did. Put the PF back down and when the game started it was making this awfully loud buzzing noise. After a few game resets I determined that when the game starts it instantly activates balls 6 & 9 as those roll over lights go out and balls 6 & 9 light up on the rack in the center of the playfield. With the PF lifted up I reset the game and I can see where 6 & 9 "lock on" as soon as the game starts but I have no idea how to fix it. I'm 99% sure it's coincidental that the game stopped working after I switched the right flipper coil, however I should ask is it possible I soldered a wire onto the wrong lug and this could be causing the issue? Other than that I have checked rollvers for 6 & 9 and I can't see anything out of the ordinary, nothing looks loose, broken, or stuck. I've attached a short video link to Youtube that shows the problem. Any advice for someone clueless like myself would be appreciated.
