I'm working on bringing a Supersonic back to life and working through things as they pop up. First I had an issue with blowing some fuses and was able to fix the power supply board by replacing the CR diodes (in another thread). Now the machine is up and running but I'm having issues with lag in switch hits and things not registering like all of the drop targets being down and not resetting. I was going to try and do a switch test but I can't get into the service menu from the door. Also, neither of the coin switches seem to register either.
Typically it's the bottom drop target, spinner, and center pop that don't work. So when I knock down all the targets they don't reset, but they do on start up and between balls. The spinner never registers and the center pop never fires. I've checked the diodes on them and the leaf switch and they test OK.
So I'm wondering, how do I fake out the MPU to get it into the service menu?
Also, I noticed that if I hold both flippers in for a few seconds I blow F4. I was flipping both at the same time and noticed the lamps dimming and just tried it and the fuse blew. Not sure what to check there. Maybe EOS switch?
