(Topic ID: 223534)
Super Straight score motor
By Photopin
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 3 years ago by zacaj
#1 3 years ago
I recently picked up a Sonic Super Straight. The drive motor unit from the score motor had been removed. The seller provided me with a Williams motor for the machine but wasn't sure if it worked.
After some testing that motor does not appear to work.
Does anyone know what the part # is for the correct motor that should go on the machine?
#2 3 years ago
The Williams motor doesn't turn, or it's not compatible with the sonic mech?
#3 3 years ago
It doesn't turn.... plus I'm not sure it's the correct one. Not sure what the correct RPM should be.
#4 3 years ago
According to my manual, it's a 14A-7884 originally, which seems to match up with williams part numbers. PBR can probably repair it
#5 3 years ago
Okay, the one I've got appears to be a 14A- 7883.
#6 3 years ago
Ah, that appears to be the 60hz equivalent of the 7884. So more proper for US operation. PBR even sells new ones if you prefer that to trying to get it repaired. I'd double check with Steve to make sure, but that motor sounds like it should work
