Picked up a Super Straight recently, and the kicker in the upper part of the shooter lane doesn't kick the ball all the way up consistently. From what I can see, when it doesn't get all the way around, the ball is bouncing back and forth horizontally a lot and using up its momentum. The wire gate also has a bend near the upper end, and I'm not sure if that's by design, or from years of wear slowly beating it into that shape, and I can't see it in any of the pictures on ipdb. Does anyone have a Super Straight with a straight wire gate, or has had this problem too?
