Score motor runs, reset relay keeps firing but sb1 and sb2 don't close. They can be manually shut closed and the motor stops. Possibly bad solenoid? Or loose wire?
Heres the startup sequence.
Mr. Pinball Tip: @ http://user.xmission.com/~daina/tips/pub/tip0538.html
The following information is taken from the March 1975 Gottlieb Super Soccer manual. This may be helpful when debugging a startup problem with this or other Gottlieb 4-player games from the same period.
1. Inserting a coin or pushing the replay button actuates 'S' relay (Start relay).
2. This relay will lock-in through its own switch and a motor 2B switch.
3. 'S' relay starts the motor running.
4. 'SB' relay and the total play meter are actuated by switches on motor 1A and motor 3B through a switch that has been closed on 'S' relay.
5. When 'SB' is tripped, the reset relays 'Z1' and 'Z2' are energized in sequence by rivets on the 'Player' unit to reset the score reels.
5a. Motor 1A steps the 'Player' unit, through switches on 'SB' and 'S' relays, to the 20th position energizing 'Z1'.
5b. When 'Z1' is energized the 1st and 2nd player score units reset to zero through switches on motor 1A, motor 4A and 'Z1'. When all score units of the 1st and 2nd player are at zero the player unit steps to the 21st position through a normally closed switch on 'Z2' and normally closed switches on all score units of the 1st two players, actuating 'Z2' relay. The 3rd and 4th player score units now reset through switches on motor 1A, motor 4A, and 'Z2'. The player unit continues to its zero position through the closed switches on 'Z1', 'Z2', 'SB2', 'P5A' and motor 1A until 'P5A' opens.
6. The control bank is reset by a switch on motor 3B through a switch on 'U' relay.
7. Inserting additional coins or pushing the replay button will actuate the 2nd player relay (PB2) through motor 3B switch: the 3rd player relay (PB3) through motor 2C and PB2 switches; and the 4th player relay (PB4) through motor 1D and PB3 switches; in that order.
8. Place the ball in the out hole. The ball return switch closes and completes the circuit to 'O' relay through the zero position switch on the bonus unit, E, 'SB1', and 'QB' relays. 'O' relay locks-in through its own switch and a switch on motor 2B. When 'O' relay is energized, motor 4C actuates the ball return coil (which kicks the ball onto the runway) through a switch on 'O' and a normally closed switches on 'P' and 'XB' relays. The ball is now on the runway and is ready to be put into play.
9. The remaining balls that enter the outhole are kicked across the trough switch which pulls in 'P' relay. 'P' relay runs the motor. Switches on 'SB', 'ZB', motor 2C, 'P', and motor 1A advances the 'Player' unit the required number of steps determined by the 'Player' unit switches and the player relays. (PB2, PB3, and PB4).
This page was printed from https://pinside.com/pinball/forum/topic/super-soccer-score-motor-wont-stop-running and we tried optimising it for printing. Some page elements may have been deliberately hidden.
