(Topic ID: 226503)
Super Soccer Lock Bar Stuck
By SDM0
2 years ago
  • 72 posts
  • 22 Pinsiders participating
  • Latest reply 2 years ago by jeffc
There are 72 posts in this topic. You are on page 2 of 2.
#51 2 years ago
I feel like I am getting suggestions from folks that have different games in mind. This is Gottlieb 1975.
#52 2 years ago
The lock bar receiver has at least two if not three screws that are going to be inaccessible before the Playfield is removed. I suppose if one was willing to break the glass, remove the acorn nut that would normally hold down the Playfield, and remove the upper play field retaining bar, then, you could slide the Playfield out towards the back of the game a bit enough to remove the screws from the lock bar receiver? You would also have to remove the shooter housing so that basically, you're removing the whole lock bar receiver!
#53 2 years ago
Here is the underside of the pf, it will be difficult to unscrew the middle plate that is held in place by the lockdown bar handle.
You'll need to either cut the hoop of the middle plate or see if you can remove the fat pin on the lockdown bar handle (it is held in place by a nut). If you do mange to pull the handle down this will probably still not release the lockdown bar pins, I expect it will just mangle the area where the handle mates to the sliding bar. BUT this should disengage the fat pin from the pf plate allowing the pf to be lifted up once glass is removed
(break the glass, break the glass )
#54 2 years ago
Have you looked up at the handle, where the pin goes through the playfield bracket? Has some one put a bolt and nut through the point where the locking pin is suppose to be?
#55 2 years ago
Did you try the bolts or screwdrivers into holes and tap on it that way yet? My phillips screwdriver was a bit big but there could be one that fits. Otherwise a good bolt that won`t bend.
#56 2 years ago
Why not take the head off, legs off and flip it over onto piece of carpet , open the coin door ( might need to prop the cab to clear the door to carpet ) and soak the mech in some 3 in one oil or plus gas or rust breaking fluid. Then at least you can see what you are doing without doing damage!
#57 2 years ago
I keep hoping with each new post that the OP proclaims "I got it open"!
#58 2 years ago
I am observing from afar, sorta hoping for a dramatic conclusion involving a chainsaw and gasoline
#59 2 years ago
It may be worth giving freeze spray, using the extension tube to pinpoint the lockdown receiver critical points, a go. I have had mixed results using freeze spray to release seized/rusted parts but others I know talk it up.
#60 2 years ago
Quoted from Classicpinballs:
You really can't get to the sliding part of the locking mechanism from the bottom. The lockbar receiver kind of hooks onto the front wooden edge of the cabinet, so there's about 2 1/2" of wood below it. The only thing really accessible from the bottom would be the lever itself, but now you're fighting gravity by trying to pull it upward.
#61 2 years ago
I wonder if he took the game outside could he use a cut off wheel to cut the lock down bar off the game (I assume these can be found easily) my thought being then he could cut the entire lock down bar off from the top side. Slide the glass out and get to the receiver from the top as well as the bottom? Both the receiver and lock down bar would need to be replaced but it should get the job done?
#62 2 years ago
Quoted from darcangeloel:
Personally, I wouldn't cut anything. I would try breaking the glass before resorting to that.
#63 2 years ago
Quoted from ForceFlow:
Even tempered glass is lower in price, than a used lock down bar.
#64 2 years ago
Quoted from Darcy:
I usually replace glass anyway. The only thing that would hold me back is the mess that it makes.
#65 2 years ago
1. Breaking the glass won't really help as the lock down bar will still be secured.
2. If the vise Grips on the lever did not allow you to pull it down to the right, determine if the acorn shaped thing is frozen to the playboard receiver. If so, unbolt it from the lever with a ratchet & socket or try to unscrew the receiver from the playboard.
3. Call the master, Steve Young, at Pinball Resource.
#66 2 years ago
I'm confused, how would busting the glass help? You would still need to get the lock bar off in order to get at the lock bar receiver right?
#67 2 years ago
Look at the suggestions above.
#68 2 years ago
If the lock down bar is unobtainable, then drilling through the bar, or cutting off the lock down bar is not an option.
Remove the legs, and backbox. First, get up inside remove the 10 screws holding the brackets for the play field, not as easy as it sounds. The plunger might be in the way, and may have to be removed too. Turn the pin on its side or upside down (on a hard surface or over a tarp), break the glass. Clean up all of the glass CAREFULLY. The playfield will be exposed, turn the game over, slide the playfield into the back of the game The playfield only needs to move back far enough to clear the lockdown bar. Then one should be able to pivot out the playfield. This should now give full access to the mounting hardware on the receiver.
Basically repeating what pinhead52 has already suggested.
#69 2 years ago
I would Not cut/drill this lock down bar- this style of lock down is expensive to replace...
#70 2 years ago
Quoted from ryan1234:
Ah got ya, yeah I didn't know if they were super common. I figured if they were common or cheap why not just cut it off but if that isn't the case then I guess not
#71 2 years ago
receivers are readily available, lockdown bars are exp/hard to find. break the glass (add a poll )
4 weeks later
#72 2 years ago
SDM0 - Any luck?
