Hi porkcarrot
I agree with @HowardR. When the pin scores 1000 points for each bonus then the L-Relay gets activated along "green line". When the pin scores 2000 points for each bonus then the L-Relay gets activated along "green line" AND sneaked in: At the same time along the "red line".
I crossed out "orange marked" --- this stuff has to do with the funny features "3 balls per play" --- "5 balls per play" --- see here http://www.ipdb.org/showpic.pl?id=2443&picno=48369 and here http://www.ipdb.org/showpic.pl?id=2443&picno=50362 .
I happen to NOT like to work on Score-Motor-Switches, Control-Bank-Relay-Switches, Interlock-Type-Relay-Switches. BEFORE I'd test Score-Motor-Switch-1B (in the red line): I would do a test telling me "Is the right side of red line good ?". I happen to have Jumper-Wires with an mounted switch in the Jumper-Wire --- I can toggle-off the pin (Safety Reasons), establish / clip-on at both sides my jumpering - the switch in the Jumper-Wire is open. I then toggle-on, start a game and at the time I WANT connection: I press the botton / close the "Switch in the Jumper-Wire". I like my Jumper-Wires with switches - I actually have "with push-and-let-go Button" as well as "with toggle-switch".
porkcarrot - want to do (?): Toggle-off the pin - locate the Adj-plug and the wire-color-yellow-black. Clip-on one Jumper-Wire and take the other end of the Jumper-Wire out into the open --- NOT touching metal. Take a second Jumper-Wire - clip-on at "Coil on L-Relay" and take the other end of the Jumper-Wire out into the open --- NOT touching metal.
Ask a friend for helping --- the friend does starting a game - playing - making bonus - then let drain the ball --- YOU hold one of the Jumper-Wires at the insulation in one hand --- and You hold the other Jumper-Wire at the insulation in the other hand --- at "Bonus-Count-Down": YOU hold together the two bare ends of the Jumper-Wires --- big question: Do You get TWO-thousands points per bonus stepped down ? (((You can do this on any ball as You are jumpering some switches)))
IF (if, if) "YES - 2000 points": The right side of "red line" is good --- further testing is needed on the "left side of red line".
IF (if, if) "NO - just the 1000 points": Further testing is needed.
I happen to have an nice JPG about Score-Motor Switches - see the second JPG. Greetings Rolf
